1994 F250 460ci E40d 4 wheel drive shifting first and second just fine. occasionally tries to shift to third but never follows through the shift ive gone through and dropped the trans fluid and pan, changed filter. nothing in the bottom of pan filter was a little dirty but after i changed the fluid and filter probelem is still there. anyone have any idea what might be goin on with it?
Is your speedometer working correctly? If so, I think your MLPS (manual lever position sensor) on the side of the transmission may need adjustment, or your shifter indicator is no longer reading correctly and it's actually in "2" instead of "D".
speedo works and its in drive but i have been having problems (holding shift lever up to start it and holding it just right for reverse lights to come on when in reverse) before when it was just starting to do it i could push the overdrive off and it would shift but now its where it is now
My truck was doing a similar thing, turned out to be a bad 2nd gear solenoid. I changed the solenoid pack because that's what the codes pointed to, it's fine now.
First, pull the codes.
Second, make sure the speedometer is working.
If it all checks out good, it's possible the intermediate clutch in the transmission is burnt out. When you apply manual second, the intermediate band also applies, which could mask a burnt out intermediate clutch.
