a new sound. - Ford Truck Enthusiasts Forums
a new sound.
Old 09-23-2013, 11:11 PM
HillBillyBuddha HillBillyBuddha is offline
HillBillyBuddha is starting off with a positive reputation.
a new sound.
About 4 or 6 weeks ago my truck started making a squeaking / chirping sound. At first I was concerned that I had blown a bearing but I became less convinced as I drove it around. But it is an annoying sound that I'd like to find and fix so I was hoping there might be some suggestions on tracking down the sound.
Here's what I can tell you about it. It only chirps / squeaks while my foot is on the gas, if I take my foot off the gas, the sound immediately stops regardless of speed. Speed doesn't seem effect the sound / pitch of the squeak. The squeak isn't always there but it only happens when my foot is on the gas. I occasionally think the sound comes from under the cab rather then the engine bay.
Any ideas?
Hillbillybuddha
Old 09-23-2013, 11:20 PM
Jklnhyd's Avatar
Jklnhyd Jklnhyd is online now
Jklnhyd has a great reputation on FTE.Jklnhyd has a great reputation on FTE.Jklnhyd has a great reputation on FTE.Jklnhyd has a great reputation on FTE.
Lol, im searching that exact same thing. Except mine is around 20 mph, and seems speed associated; i slow down, it slows down. Im staying home tomorrow, which i cant afford, to try and figure it out. I was reading my Chiltons, maybe my tranny fluid or band adjustment? Idk
Old 09-24-2013, 07:41 AM
tinman52's Avatar
tinman52 tinman52 is online now
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
I would check your U joints first......
Old 09-24-2013, 08:39 AM
old broke prospector old broke prospector is offline
old broke prospector is gaining momentum as a positive member of FTE.old broke prospector is gaining momentum as a positive member of FTE.
I would be thinking torque related, when under load or accelerating, the engine will torque and that very slight movement may be causing something to rub or wear. Sadly it can be anything.
Use a cell phone in a plastic bag, tape it in the engine compartment, call another phone and listen on that phone for the sound as you drive, then test the tranny, then the rear end. It may be better to jack up the rear wheels and do the test in the drive way to reduce the road noise.
Of course it could be grimlins in the gas tank complaining that you are draining their food supply.
Old 09-24-2013, 01:48 PM
Thanks for the suggestions. I'll try the phone idea, but might not need it if I just Jack up the back end.
I'll check my U joints too
JkInHyd, hope you figure your issue out.
Old 09-26-2013, 12:27 AM
The Masked Rider The Masked Rider is offline
The Masked Rider is gaining momentum as a positive member of FTE.
"chirping sound" Are you sure its not a tiny exhaust leak.
Old 09-26-2013, 05:58 AM
Quote:
There's nothing tiny about my exhaust leak. I can almost get my fist into that "leak" It's part of my "to do" list. On that note, I found a pair of hooker headers at the junk yard today.
Old 10-09-2013, 06:47 PM
Jklnhyd's Avatar
I replaced the u joints on my rear drive shaft and the problem is gone. I actually had climbed under before and pushed and pulled, and saw no sloppiness, but when i actually removed em, they were already dried out and destroyed.
moving Squeak suspension noise> not sure where it's coming from HiZ Excursion - King of SUVs 4 10-24-2016 10:04 PM
2000 Excursion V10 Camshaft Position Sensor Kevwood442 Excursion - King of SUVs 10 10-11-2016 09:09 PM
Help!! Plz newb here 6.0 chirping loud Mikelangevin 1999 to 2016 Super Duty 8 04-10-2016 12:09 PM
Chirping in bell housing Bob Montoya 2004 - 2008 F150 1 01-08-2016 07:38 AM
Do u-joints cause squeaking in reverse? Ranger Steve Ranger & B-Series 1 09-06-2006 06:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
