ford 300 inline 6 engine - Ford Truck Enthusiasts Forums
Old 09-24-2013, 12:02 AM
divcotruck divcotruck is offline
divcotruck is starting off with a positive reputation.
I need to take this engine out of my truck. I am learning as I go I am new to this board and I appreciate any help. is there any documentation or can anyone tell me how to begin taking this engine out. thank you
Old 09-24-2013, 12:26 AM
Samsn4's Avatar
Samsn4 Samsn4 is offline
Samsn4 is gaining momentum as a positive member of FTE.
I always start with electrical, either take pics of all the connections or tape and a marker to label them. then any liquid lines, coolant, fuel, etc. Pull the radiator to get it out of the way to not damage it, then free the motor from the mounts, then do a last check for any thing that was missed to disconnect, and pull it out. no real tricks that I've learned. If your pulling motor and trans as one then be prepared for all the trans fluid to dump out the tail, might even be easier to pull the grill and radiator support to not have to lift it so high. good luck take lots of pic before to be able to know what went where.
Old 09-24-2013, 09:06 AM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is online now
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
x2
There's no real "trick" to removing an engine. Drain all the fluids first. Mark where EVERYTHING goes. Document, take pictures, then take more pictures, and document some more.
Disconnect everything that's attached to it and put it safely out of the way. Unbolt it from the motor mounts, unbolt it from the transmission, and then hook a hoist to it and slowly lift it out. If it tilts to one side while you're lifting, or tweaks, or anything funny, stop immediately and make sure you didn't miss something that was connected to it. Commonly missed things are power steering lines, ground straps, etc.
Make sure you have a strongly rated chain, find a good place to connect a chain to (big bolts through the links into the block or head works well), and never get under it while it's lifted.
Most importantly, take your time.
Old 09-24-2013, 09:15 AM
thank you gentlemen!
400 engine advice... CBA3 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-19-2015 09:12 PM
What parts to take for free ? Out of a e350 ssian 1999 - 2003 7.3L Power Stroke Diesel 15 10-02-2014 06:37 PM
High output on take off G-White 1997 - 2003 F150 1 06-30-2014 11:05 AM
hesitation/ no power when engine is lugging Hotpocket 1999 to 2016 Super Duty 16 06-04-2014 12:46 PM
Injector O-ring replacement rocketman2440 1999 - 2003 7.3L Power Stroke Diesel 21 01-25-2011 09:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
