Scraping or Screeching Noise
So sometimes my 98 F-250 is making a screeching noise I believe is coming from the front end at lower speeds. Kinda like nails on a chalk board screeching noise, but it comes and goes at random. Front brakes are only a year old, pads and rotors so I'm doubtful thats it. I've also done a bunch of other front end work this summer but the noise has been there before any of that. I know the serpentine belt squeeks sometimes too, but its new and I haven't dove into that problem much yet.
Might be wise to remove the serpentine belt ( engine off) and spin individual components by hand of which the belt drives and see if you can get the noise to repeat.
With belt off... maybe take a short drive & see if the noise come back...if not...then it prolly is part of the belt system and needs closer look...if it does...then it prolly part of the front end like the 1st thought above or wheel bearing or such.
Maybe you just got something stuck under there and need to be removed
olderf150
12-13-2013 01:39 PM
