EGR Block off plate / Detonation - Ford Truck Enthusiasts Forums
Old 09-23-2013, 10:22 PM
bcboy4ca's Avatar
bcboy4ca bcboy4ca is offline
bcboy4ca is gaining momentum as a positive member of FTE.
Hi everyone, my truck (93 F150 5.0L/E4OD) was having some minor surging issues while cruising through town with light throttle around 1500rpm. I did some searching on here and found someone with similar issues that resolved it by blocking off the EGR.
I made an EGR block off plate and installed it on the weekend, took it for a drive around town and the surging is gone, that is the good news.
Today I took the truck to work and noticed that I am experiencing some detonation even under minimal load. Prior to the EGR block off plate I did the SixLitre tuneup and didn't have any detonation issues. Is the detonation a result of blocking off the EGR or something else?
In the meantime I am going to retard the timing a bit.
On another plus side, I got 18.97mpg out of the old girl today , not too bad for a 20 year old truck with 307,000 kilometers on it.
Old 09-23-2013, 11:14 PM
timbersteel's Avatar
timbersteel timbersteel is offline
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
I would remove the EGR block off plate. I doesn't help you with your detonation problem. EGR helps to reduce cylinder head temps and if you haven't modified the engine to run without, then its only going to make a small problem, BIGGER.
When you developed a surge at light cruise, did you ever check for codes or perform the "Key On, Engine Running" test? I bet it would help and probably pinpoint your problem to either a carboned up EGR valve, malfunctioning EVP sensor, or the EGR Vacuum Solenoid has decided to go bad. And they do. Could even be a broke vacuum line for those above components that needs replaced and it would an easy fix.
Let us know what else you have troubleshooted and we'll try to help you out.
Old 06-06-2014, 03:09 PM
Slowroll90 Slowroll90 is offline
Slowroll90 is starting off with a positive reputation.
Quote:
How does EGR reduce cylinder head temps?
Old 06-07-2014, 09:47 AM
I happen to come across this link.
http://aftermarket.federalmogul.com/...reignition.pdf
Exhaust Gas Recirculation (EGR)
Google or Bing is your friend!
2000 2.5 Ranger Detonation Issues SHOpar Ranger & B-Series 1 01-23-2015 12:26 AM
92 F150 CEL Code Issue 5.0L offrdmania 1987 - 1996 F150 & Larger F-Series Trucks 9 09-24-2014 01:04 PM
What can ya tell me about pinging? nothercrash 1973 - 1979 F-100 & Larger F-Series Trucks 10 12-25-2010 02:25 PM
85 F350 Carb EGR lavatan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 12-19-2010 08:00 AM
Detonation/pinging issues with C-1AE heads??? Annihilator FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 20 09-28-2004 07:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
