292 camshaft won't slide out...
Old 09-25-2013, 09:21 AM
JBravo's Avatar
JBravo
JBravo is offline
I can get it out of the cam bearings that it rides in but it jams up when I try to get it thru the next set? Any suggestions...
Bravo
Old 09-25-2013, 03:33 PM
charliemccraney's Avatar
charliemccraney
charliemccraney is offline
You need to make sure you are pulling it straight out. If it is tilted slightly in any direction, it won't move.
Try wiggling it around gently while pulling.
Put the cam gear back on and try rotating the cam while pulling. The cam gear also simply gives you something more substantial to hold onto.
Old 09-25-2013, 04:38 PM
JBravo's Avatar
JBravo
JBravo is offline
Wish it was that simple... The next set of journals line up to slide thru the cam bearings but it just tightens up and bottoms out more or less...
Old 09-25-2013, 06:50 PM
JBravo's Avatar
JBravo
JBravo is offline
got it... took some coaxing from the backside but it slid out... cam and bearings are being replaced so I decided a few friendly taps with a dead blow hammer wouldn't hurt...
Bravo
Old 09-25-2013, 09:21 PM
DCP's Avatar
DCP
DCP is offline
Bravo
292 blocks are know to wrap especially the ones that come out of the medium duty trucks. If you just install new cam bearings you might find out that the cam won't go back in or you will have a tight turning cam. You might have to have our cam journals line bored to get your cam to go back in and not running tight. I also read where some people had angled their cam bearings to compensate for the wrap.
Old 09-26-2013, 11:03 AM
JBravo's Avatar
JBravo
JBravo is offline
thanks for that info... I'll make sure the machine shop checks that when I take the block in...
Bravo
Old 09-26-2013, 01:04 PM
schoo's Avatar
schoo
schoo is offline
would like to see some pic of this engine build
Old 09-26-2013, 02:35 PM
JBravo's Avatar
JBravo
JBravo is offline
Right now its blown apart on my workbench and garage floor... Planning on a mild build... 292 .040 over... Looking for a Offy or Edelbrock 3x2 intake if anyone has any leads...
Old 09-26-2013, 03:19 PM
schoo's Avatar
schoo
schoo is offline
not pushin just like pic, childhood thing
Old 09-26-2013, 03:58 PM
charliemccraney
The Offy is the worst but they are plentiful and it seems like there is always one on ebay.
If you like the looks of the 3-2's. I completely understand but if you want to get the most power, stick with a single 4 barrel and at least the ECZ-9425-B intake. Since you are considering 3-2s, even an aftermarket Mummert or Blue Thunder 4 barrel intake probably fits into the budget.
Even the best 3-2 intake, the Edelbrock 573, doesn't match the factory ECZ-9425-B intake. However, the Edelbrock or Edmunds intakes have great low end torque.
Some links with more info:
Intake manifold testing on the new heads
3X2 Intake Manifold Testing - Results.
Old 09-26-2013, 11:07 PM
Y-Blockhead's Avatar
Y-Blockhead
Y-Blockhead is offline
[QUOTE=charliemccraney;13568983]
The 573 with Strombergs does make more HP and torque than the "B" manifold in the dyno test. I have both and I normally like the "B" manifold with a 500 cfm Edelbrock for "normal" driving but put the three Strombergs on for WOW factor at a cruise.
Like Charlie said, stay away from the Offy manifold. It is a 360° design and the lower ports tend to flood.
Old 09-29-2013, 10:40 PM
46yblock's Avatar
46yblock
46yblock is offline
No offense intended to anyone, but a 3X2 setup isnt terribly unusual, especially at a car show. Some like Dennis' are unusual in their detail and precision, but most arent.
I have long suspected that the reason there seem to always be 3X2 intakes available is that guys set them up, dont like them after 1 or two years, and put them back on the market. IMHO.
Old 09-30-2013, 12:19 AM
Y-Blockhead
One thing guys don't think about with a 3x2 setup is cost. Nowadays 3 new Stromberg 97's will run you ~$1350, not counting the cost of manifold, air cleaners, linkage, etc. The new Edelbrock 94's are about the same.
Sure you can get used carbs but first you have to buy good cores. And remember these carbs are 50+ years old. Some Strombergs are from the thirties. The cores are not going to be cheap. Take a look on ebay.
To rebuild them is not cheap either... you have to buy three of everything. Especially if you need new throttle shafts and bushings (http://www.summitracing.com/parts/SBC-9581K/), jets, pumps, etc.
Most people would be happier with a single four barrel on a good manifold.
Don't get me wrong, I love the looks and dig the hell out of the sound when I open up the secondaries and not trying to talk anyone out of their plans. But there is also better places you could be spending your money. I would suggest you wait until after you get the truck running the way you want then get the 3 deuces.
IntheTrees
08-04-2009 07:19 AM
crawlfish
06-08-2005 06:10 PM
MudinMan19704x4
02-29-2004 11:33 PM
lentz321
05-15-2003 07:16 PM
58ford
04-29-2002 12:04 AM
Quick Reply: 292 camshaft won't slide out...
