55 f100 Dolphin Electronic Speedo
Old 09-22-2013, 08:02 PM
DGMFORD's Avatar
DGMFORD
DGMFORD is offline
Has anyone been successful in programing the Dolphin Electronic Speedo with a ford C6?
I've gone through the frequency calibration and the distance calibration and it does appear the odometer is working right however the speedo is not. After running the mileage calibration, it set a frequency number of F00607. the original setting from the book of F00330.
When I drive, the speedo jumps up to about 60 or 70 then settles down at around 30 and won't go no high or lower unless you come to a complete stop.
I changed the frequency number back to the f00330 and its back up to 70/80 when I drive.
I get setting the frequency number but don't understand why it jumps so high then settles back down.
thanks
Old 09-23-2013, 09:01 AM
53FOPAR's Avatar
53FOPAR
53FOPAR is offline
Sounds like something wrong in the speedo head to me. I did the calibration process and the speedo is right on when I check it with GPS.
I'd call Dolphin and talk to tech support. I had an issue with EZ wire (same company) and they were great at working me through it.
Old 09-23-2013, 10:35 PM
DGMFORD's Avatar
DGMFORD
DGMFORD is offline
Thanks for the reply, I called them today and they helped me fix the problem. The problem was my fault, when I hooked up the pulse gen, I ran 12v power to one leg of the sensor and the other to the speedo. The guys at Dolphin said it's one wire to the speedo and the other wire is a ground. Made the change and all works perfect. I'm surprised I didn't fry the sensor.
thanks
Aussie BrianB
Australia Chapter
41
07-27-2013 09:53 PM
Aquik72
1999 to 2016 Super Duty
06-07-2010 09:25 AM
1950gmcelc
02-16-2009 01:57 PM
WXboy
08-28-2003 12:05 AM
Quick Reply: 55 f100 Dolphin Electronic Speedo
