Denny,is there any Magic Air Heater that will mount up the same as a standard heater in a 1952 F-1? It looks like to me that there is a extra stud and the core tubes are located different?
Magic Air & standard box type heater have a different set of mounting studs & the core tubes are also different . See post 121 .
34 pcs. of Magic Air heater parts & other species media blasted & primed .Picking up at least a dozen more heaters, fresh air tubes & other related parts on the " Great 2016 Parts Safari " to Ga. , Wis. ,& S.E. Mn. Sept 28 - Oct 6
My wife just lost her job so all nu-necessary expenses just got put on hold. Bummer, I am really looking forward to getting one of your rebuilt fresh air heaters. Hopefully next year...
Acquired 11 Magic Air heaters , 5 FORD script fresh air heaters , a very large box full of fresh air tubes , a small box of '48-'50 fresh air tube elbows . extra motor cover emblems '51 & '52 , a LS door for a very good buddy building a '52 . and a bench seat to deliver in GA. . Will also deliver his complete '52 Magic Air heater system early next week .Junk yardin' Tues. , Wed ,& Thur. Have 3 more Magic Air heater systems to pick up in S.E. Mn. along w/ a 3 pc. fresh air tube & some splash guards .
Before & after heater core tanks , restored Magic Air heater interior case heat / temp doors w new felt seals replacing them is a pita , restored fresh air door housings w/ new felt seals on fresh air door . Made a modification to a c-clamp on the lathe to compress the 1/8 " blind rivet .
Attention clean up needed on 128 pcs . of Magic Air heater hardware . Defrost ducts , fresh air doors & housings . cable control panels , defrost doors , '48-'50 adapter rings & clamp will also be submitted to the media blast cabinet .
I have a 1950 ford f1 with a ford script fresh air heated and am missing both defrost ducts and the flange that mounts on the inside of the cab opposite of the motor that is in the fender well. Does anyone have these?
