no brake lights - Ford Truck Enthusiasts Forums
no brake lights
Old 09-22-2013, 02:38 AM
1981Ranger's Avatar
1981Ranger 1981Ranger is offline
1981Ranger is starting off with a positive reputation.
no brake lights
I have no brake lights but when i turn my lights on they come on i dont know if i need a new brake switch or what
Old 09-22-2013, 06:56 AM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Do you have a testlight? If not, go buy one. Play around with it at the battery and see how it works. Then get under the dash and clip the one wire to a good ground, and then probe the two green wires going to the brake switch on the pedal arm. One wire should be hot all the time(light the testlight up all the time) and the other wire should light the testlight only when you push on the pedal with your hand.
No brake light or hazards Keith Free 1978 - 1996 Big Bronco 4 09-04-2016 12:52 PM
1988 brake light problem wrd0225 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 6 05-04-2016 03:49 PM
No Brake Lights Larzon 1987 - 1996 F150 & Larger F-Series Trucks 3 11-18-2012 06:56 PM
Wiring brake light. RÖENTGEEP 1994.5 - 1997 7.3L Power Stroke Diesel 22 02-23-2009 03:53 PM
brake switch won't turn brake lights off samralh Explorer, Sport Trac, Mountaineer & Aviator 5 10-14-2004 11:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
