Spark plugs - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Spark plugs
Old 09-21-2013, 09:33 PM
Boomer1956 Boomer1956 is offline
Boomer1956 is starting off with a positive reputation.
Spark plugs
2007 El Limited, 81K. I am very capable of doing mechanical work. Brakes, ball joints, tie rod ends, o2 sensors, window regulator to name a few. I am very concerned about all the messages about these 5.4's and the spark plug issues. I am considering taking it to my dealer and letting them change the plugs. Any questions I should be asking and about what price can I expect.
Old 09-21-2013, 10:50 PM
Boston Mark Boston Mark is offline
Boston Mark is starting off with a positive reputation.
I've heard the engine has to be COLD COLD COLD!
Like room tempeture cold.
Old 09-22-2013, 07:56 AM
thinksnow thinksnow is offline
thinksnow is starting off with a positive reputation.
I reluctantly did it myself figuring if one breaks I will by the removal tool and go from there. I followed the procedure I found on this site, someone had posted a video link.
-first I did a seafoam induction hot bake.
-using my shop vac and some down sized tubing I picked up from HD I vacuumed all the dirt/sand that finds its way down by the spark plug. You will be surprised at whats down there. You certainly don't want that debris falling down into the cylinder.
-next using a ratchet I gave each plug a 1/4 to 1/2 turn followed by a good dose of PB blaster. Then I let it sit for 2 hours
-from there I used a mini electric impact wrench. The smallest one I could find as space is tight. It certainly took some fanageling on some of the plugs.
Every plug came out without a problem.
Bosch Bare-Tool PS41B 12-Volt Max Lithium-Ion 1/4-Inch Hex Impact Driver - Amazon.com Bosch Bare-Tool PS41B 12-Volt Max Lithium-Ion 1/4-Inch Hex Impact Driver - Amazon.com
Old 09-22-2013, 04:33 PM
That IS good news! I'm really glad you took UR time and all went well.
What did the old ones look like? Did You dress the new plugs for next time?
Old 09-22-2013, 04:53 PM
I put anti seize all the way up the threads and neck of the new plugs. I have a pic of the old ones but for the life of me cannot figure out how to upload it.
Old 09-22-2013, 05:58 PM
clarky03 clarky03 is offline
clarky03 is starting off with a positive reputation.
That's some good info there.ill have to keep that in mind
weak spark Hardlanding 1987 - 1996 F150 & Larger F-Series Trucks 3 09-01-2015 07:41 AM
Broken Spark Plugs Dwayne42 2004 - 2008 F150 68 09-13-2014 10:35 AM
4.2 spark plug - any issues? chuckczrxoa 2004 - 2008 F150 9 11-16-2013 07:46 PM
E3 spark plugs Boss_hoss Modular V10 (6.8l) 3 03-04-2010 05:57 PM
spark plug question RangerBlues Electrical Systems/Wiring 6 12-14-2006 10:15 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
