Idle surge - Ford Truck Enthusiasts Forums
Idle surge
Old 09-21-2013, 07:43 PM
almonyspm1 almonyspm1 is offline
almonyspm1 is starting off with a positive reputation.
Idle surge
92 f150 302. I had a idle surge problem pretty bad, but I fixed a vacuum leak and replaced my tps. Check engine light went off and it runs much better. However I still have idle surge, but only if I let my truck idle for a little bit or if I let it sit at idle when I start it up. If I start it up and just take off I have NO idle surge. So any ideas what this could be?
Old 09-21-2013, 07:55 PM
timbersteel's Avatar
timbersteel timbersteel is online now
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
Idle lope...vacuum leak.
No codes now? Run Key On, Engine Running test. How's the PCV valve? Pull the PCV valve and with engine idling, take a sheet of paper, and allow it to block flow off. Does the idle lope quit? Vacuum leak.
Old 09-21-2013, 08:12 PM
I will try that. Could it be idle air control valve?
Old 09-21-2013, 08:27 PM
Not necessarily. The IAC valve tries to control for a steady idle or to increase say for turning or Air conditioning compressor. I would double check ALL vacuum lines and inspect both vacuum reservoirs.
Edit: A non functioning IAC would result in low idle/stalling condition.
surging idle sdawe 1987 - 1996 F150 & Larger F-Series Trucks 2 10-07-2016 11:55 AM
1989 f150 4.9L ROUGH IDLE sdawe 1987 - 1996 F150 & Larger F-Series Trucks 0 10-06-2016 07:53 PM
SURGING idle fordboy97 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2015 01:28 PM
Engine Surging at Idle cajunsuperduty 6.0L Power Stroke Diesel 9 10-28-2011 03:31 PM
no power, surging wintremute 3.0L V6 1 05-16-2006 08:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
