Max Power, Sub 4000 rpm Build, Stock Appearance? - Ford Truck Enthusiasts Forums
Old 09-21-2013, 08:08 PM
Franken-Truck's Avatar
Franken-Truck Franken-Truck is offline
Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.Franken-Truck has a very good reputation on FTE.
This is for my 1987 F250. It's cherry inside and out, only thing really wrong with it is the PO painted over the factory red/silver paint with solid red. I want to try and make it a bit more "boner-rific" to drive on the weekends, yet still look factory stock. That means exhaust manifolds, all the smog stuff, plumbing, canisters, etc. The fact that it is 100% there and functional is kinda cool, and I'd like to keep it that way
Currently:
-D1VE 460, .10 over
-EFI pistons
-Straight up timing
-Generic "RV" cam
-E6TE heads? Stock valves, ground out thermactor hump
-Stock Dizzy
-Generic Summit 3" single out the back.
Backed by a c6 that needs a rebuild. 33" tires, 3.55 gears. Not sure what the HP/TRQ are like, but it is not disappointing to drive. I would like more pep though, and there is a slight possibility of it being tasked to tow a 33ft sailboat once every couple of years in the future. . .ever so slight. . .
I have no power goals, only that I want the most that is "reasonable" and fun to drive around town, for the restrictions I've placed on the build (passing gear on the highway is like 3500 RPM ). My first instinct is a stroker kit (like a 545ci) wrapped around basically a stock upper end. . .but I'm not sure I do have the D9TE block to use.
Any and all help and advice is appreciated!!
Old 09-21-2013, 08:41 PM
97puller's Avatar
97puller 97puller is offline
97puller is starting off with a positive reputation.
Is it carbureted or EFI?
Old 09-21-2013, 08:46 PM
Factory Carb'd, sorry. . .
Old 09-22-2013, 09:59 AM
97puller's Avatar
You could get your heads professionally ported with bigger valves. You might be able to find some one that will port your stock intake and exhaust manifolds too. Order a custom ground cam from an experienced big block ford builder, they don't cost much more than a generic one. The duraspark distributor can be recurved for better performance also. You might not have enough air flow to gain much from a stroker, you will have to ask an experienced engine builder about that.
Old 09-24-2013, 01:06 PM
Air flow is a concern. Not sure of any experienced local builders. . .could give Scott a call. . .might post this over on 460ford as well. I do have hope though, some of those guys in F.A.S.T. make serious power on a "stock" motor
Thanks
E4OD Build Questions williameub 1994.5 - 1997 7.3L Power Stroke Diesel 21 03-07-2016 10:13 PM
2008 Ford F-350 Crewcab Longbed Powerstroke/ZF6 slowcoupe Vehicles for Sale 6 10-23-2015 06:32 PM
My Impressions Driving a Tuned vs Un-tuned 7.3 ARW 1999 - 2003 7.3L Power Stroke Diesel 36 10-04-2015 12:44 PM
64 F100/94 350 4x4 Frame Swap/Upgrade and Restoration WhitefishBoy64 1961 - 1966 F-100 & Larger F-Series Trucks 25 12-10-2013 03:10 AM
Archionís Build Thread AKA "Project 359" Archion 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 02-18-2013 12:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
