gearing recommendations
hey guys
just wondering if anyone can help me out with gearing recommendations for my truck the gears are stock right now.
i have a 06 f 350 with a carli lift and 38 inch tires
head studs, egr delete, idp street tunes and mtw hybrid turbo
i dont tow often but do probably equal city and highway driving.
also im up and down logging roads fairly often.
i would definitely like to see it quicker off the line.
thanks
thanks
So currently you're running the factory 3:73 (axle code 3L on the door sticker)?
Here's a handy chart with all the Ford axle codes:
Ford F-250/350 Series Gear Ratios
What rpm are you turning at 65mph? I run stock size 235-85-16 (31 inches tall) with factory 4:10 gears, and my truck is a beast off the line. At 65mph its turning 2000rpm on the nose. With you running 38"s I would think you would need to go lower than 4:10... Maybe 4:56 would be closer to what you need.
moose94
08-27-2003 11:27 AM
