1983 Ford NU-WA RV w/460 V8 - Ford Truck Enthusiasts Forums
Old 09-21-2013, 11:28 AM
ptt ptt is offline
ptt is starting off with a positive reputation.
I have acquired a 1983 Class C motorhome. It has an allegedly rebuilt 460 V8 w/big Edlebrock 4bbl carburetor. The transmission is the C6 with a GEAR VENDOR OVERDRIVE installed on it. I don't know a lot about the vehicle but it seems to run and shift good and the dash AC works!. The advantage of having the GEAR VENDOR OD seems to be lost because the kickdown system needs adjusted. In auto-mode the kickdown causes the transmission to downshift on even the slightest grade so MPG gains are lost from constant downshifting. Previous owner said he just used the OD in the manual mode. It has the foot-operated button on the driverside wheelwell hump near the high/low beam foot-button easy to miss the correct button and hit the high/low beams if not careful. Is there a way to adjust the kickdown (rod?) to not downshift the transmission so quickly? Thoughts appreciated. Also have the huge chrome plated Edlebrock 4bbl carb that almost has to be feathered to get to highway speeds of 60-70mph without sputtering and occasionally backfiring out the exhaust. Thanks!
Kickdown lever from c6 transmission GreenGorilla 1973 - 1979 F-100 & Larger F-Series Trucks 12 12-24-2015 03:24 PM
5 Star Tuning - 2.7 EcoBoost Tuning fordmdb Vendor Specials, Discounts, Product Announcements & Group Buys 0 08-21-2015 10:52 AM
My 86 has a high shift point and kicks down too easy mvvette97 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 7 01-05-2015 08:18 AM
1998 E Super duty RV E4OD Transmission AF_MAC Clutch, Transmission, Differential, Axle & Transfer Case 5 07-05-2014 06:45 PM
1989 Ford Ranger 2,9 V6 - Engine Hesitation hinderaker Ranger & B-Series 2 06-13-2013 04:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
