6.2L V8 Discuss the 6.2L V8
2011 f250 6.2 exhaust systems?
Old 09-21-2013, 10:27 AM
BlueOvalJunkie11's Avatar
BlueOvalJunkie11
BlueOvalJunkie11 is offline
why does every aftermarket system only fit a crew cab? if it only involves cutting pipes ill buy one but no company can give me an answer.
Old 09-21-2013, 11:45 AM
Beechkid's Avatar
Beechkid
Beechkid is offline
IMHO, you will have as good or better fitting system (and quality) if you have a local shop build & install.
Old 09-21-2013, 12:07 PM
BlueOvalJunkie11
I don't have a real good shop around here and I really like the Gibson exhaust. It don't make sense that they only off for a crew cab
Old 09-21-2013, 02:48 PM
acf6's Avatar
acf6
acf6 is offline
Its only for a crew cab because thats the longest amount of pipe needed. Theres one piece in every kit that you cut to length for the cab/bed configuration
Old 09-21-2013, 05:15 PM
bikerman2299's Avatar
bikerman2299
bikerman2299 is offline
I used a flowmaster cat-back kit on my '11 super cab. It worked out great. Its not obscenely loud unless you put your foot in it, and the only cutting I had to do was cut the old stuff out of the way.
Old 09-22-2013, 01:17 AM
BlueOvalJunkie11
so basically its just shortening pipe? im tempted on buying this gibson exhaust (9118 kit) but i just want to make sure that it just involves shorting pipe than it turning into a big mess
dubnasty216
1999 to 2016 Super Duty
12-10-2014 11:00 PM
drizzie27
02-13-2012 02:07 PM
Menghi08LT
03-05-2011 11:25 PM
jstnromero
2004 - 2008 F150
11-17-2008 10:13 PM
iwantanf150
2004 - 2008 F150
08-27-2007 11:58 AM
Quick Reply: 2011 f250 6.2 exhaust systems?
