2011 f250 6.2 exhaust systems? - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 09-21-2013, 11:27 AM
BlueOvalJunkie11 BlueOvalJunkie11 is offline
BlueOvalJunkie11 is starting off with a positive reputation.
why does every aftermarket system only fit a crew cab? if it only involves cutting pipes ill buy one but no company can give me an answer.
Old 09-21-2013, 12:45 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
IMHO, you will have as good or better fitting system (and quality) if you have a local shop build & install.
Old 09-21-2013, 01:07 PM
I don't have a real good shop around here and I really like the Gibson exhaust. It don't make sense that they only off for a crew cab
Old 09-21-2013, 03:48 PM
acf6's Avatar
acf6 acf6 is online now
acf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputation
Its only for a crew cab because thats the longest amount of pipe needed. Theres one piece in every kit that you cut to length for the cab/bed configuration
Old 09-21-2013, 06:15 PM
bikerman2299 bikerman2299 is offline
bikerman2299 is starting off with a positive reputation.
I used a flowmaster cat-back kit on my '11 super cab. It worked out great. Its not obscenely loud unless you put your foot in it, and the only cutting I had to do was cut the old stuff out of the way.
Old 09-22-2013, 02:17 AM
so basically its just shortening pipe? im tempted on buying this gibson exhaust (9118 kit) but i just want to make sure that it just involves shorting pipe than it turning into a big mess
Riffraff CCV Mod SARDiverDan 1999 - 2003 7.3L Power Stroke Diesel 11 01-11-2014 04:43 PM
Tire Pressure Monitoring System nut1605 6.7L Power Stroke Diesel 11 11-28-2010 11:06 AM
Trailmaster 6" suspension system Scratcha 2004 - 2008 F150 10 03-22-2010 05:21 PM
Exhaust fumes in cab...anyone get it figured out yet? 1BADRIDE 6.0L Power Stroke Diesel 36 12-30-2004 07:05 PM
1984 F150 Speaker system? presleyfam4 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 03-05-2004 06:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
