Stranded... Please help
The truck all of the sudden is not starting for me. The batteries are new and it's getting plenty of juice. When I turn the key it clicks and my only guess is the starter. Would that indicate a bad starter or a ground problem somewhere? Please help and thanks in advance!
That means the starter is good.
One other test - pull the connector off the SMALL terminal on the relay, and run a jumper between that and the battery. If it starts with that, then the relay is good and the problem is "upstream" - wiring, neutral/clutch switch (auto or manual BTW?), ignition switch, etc. If it clicks the relay but still doesn't start, then the relay is faulty - making noise but not actually contacting.
The starter relay is on the passenger side fender well
The starter is under the truck passenger side attached to the bell housing with 3 large bolts.
The starter solenoid has one large wire and one small wire connected to, it is mounted to the starter motor
brokentv
21
04-16-2012 01:29 PM
patmorrison
13
02-27-2004 03:20 PM
