Kickdown rod grommet
Old 09-20-2013, 05:02 PM
djmichael24951's Avatar
djmichael24951
djmichael24951 is offline
On my 79 Ford F150, C6 Tranny, where can I find a grommet for my kickdown rod?
Old 09-20-2013, 05:58 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
I looked in the parts catalog and don't see any listing for just the grommet.
The only items I see are the kick down rod, the retainer clip and a snap ring, nothing listing the grommet.
In the illustrations there's no breakout for the grommet either, just the complete kickdown rod.
Old 09-20-2013, 06:35 PM
Roger Carter's Avatar
Roger Carter
Roger Carter is offline
Typically the grommet is part of the kickdown rod. Ford does not offer them as a separate part.
I have used steel or bronze bushings to replace broken grommets. Most of the better hardware stores carry a decent selection.
Good luck.
Roger Carter
Old 09-20-2013, 07:15 PM
djmichael24951
I was afraid of that. I stuck a piece of rubber in there for now. Not sure how long it will last.
Old 09-20-2013, 07:17 PM
djmichael24951
kickdown
What catalog are you speaking of? I can still purchase one new somewhere?
Old 09-20-2013, 08:13 PM
mikeo0o0o0's Avatar
mikeo0o0o0
The Ford Master Parts catalog. Its available on CD from hipoparts.
HiPo Parts Garage
Old 09-21-2013, 03:56 AM
miottimouse's Avatar
miottimouse
miottimouse is offline
24951 here is an ebay listing number [cp power train] they have them for $5.00 each I just bought 4 in the 3/8 size listing # 271032148252 just make sure you use a heat gun or a hair dryer to warm them up before install hope this helps
Old 09-21-2013, 08:19 AM
djmichael24951
Question grommet
I just searched that number, and also cp power train, and came up with nothing. Is there a particular way to search?
Old 09-21-2013, 08:41 AM
jim collins's Avatar
jim collins
jim collins is offline
Old 09-21-2013, 10:40 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
What size is the engine?
Old 09-21-2013, 11:16 AM
djmichael24951
kickdown
It is a 351M.
Old 09-21-2013, 11:48 AM
NumberDummy
It is a 351M.
Reason I asked for the engine size, there are different pics for: 300 - 302 - 351M/400 - 460.
There is no bushing available by itself, as it's made as part of and only available with the kickdown rod (no bushing available for 300/302/460 rods either).
97409-S8 .. Retaining Clip - 17/32" O.D x 13/64" I.D. x 1/32" thick.
The nylon 'snap-in' bushing on the manual control selector lever on the L/S of the trans case...that the shift rod attaches to, same as the nylon bushing on the selector lever on the steering column are available separately.
EOSZ-7341-B (replaced D5AZ-7341-C - DOAZ-7341-A - C7SZ-7341-D - C3AZ-7341-A) .. Nylon Selector Lever Bushing / Available from Ford ~ MSRP: $4.22 each.
Myriad 1963/96 FoMoCo vehicles.
Old 09-21-2013, 07:33 PM
miottimouse
send me your email address I will see if I can send you the ebay page regards joe
jmiotti@telus.net
Old 09-21-2013, 10:23 PM
djmichael24951
Kickdown
jmiotti@telus.net
djmichael24951@gmail.com. Thanks Joe
Old 09-23-2013, 06:18 AM
miottimouse
email sent with the page hope this helps regards joe
fabieber
12-20-2015 12:51 AM
chopper269
1997-2006 Expedition & Navigator
07-23-2006 01:48 PM
Randyb12
03-12-2004 06:37 PM
1 Big Mike
09-19-2002 06:44 PM
Quick Reply: Kickdown rod grommet
