429 Help... - Ford Truck Enthusiasts Forums
429 Help...
Old 09-20-2013, 02:16 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
429 Help...
I am looking for a 429 for a 1994 F700. 1)Does anyone know if these are different than the motors found in non-heavy duty trucks?
If so, can anyone help me locate a crate or rebuilt 429 for this truck? Thanks.
Old 09-20-2013, 02:40 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Your prior post has a source:
http://www.ford-trucks.com/forums/12...ne-source.html
429s were never used in light duty trucks other than the Ranchero. The 429 in mediums like yours is different from that engine, and different from the PU/car 460s, making a direct swap impractical.
"Different" as in crank snout, mounting, accessory drives, bell, clutch, pilot hole in crank, along with the heads, intake, exhaust etc.
Old 09-30-2013, 09:36 AM
Monsterford34 Monsterford34 is offline
Monsterford34 is starting off with a positive reputation.
It can be done but not recomended. The 429 for trucks used a steel crank I believe as compared to a cast crank. They had calcium I believe in the heads also. One thing though is what will you be using the truck for?
1982 f-800 429ci to allison mt653 HELP davischas Large Truck 1 05-26-2015 01:19 PM
429 Horsepower Mr. Mcbeevee Large Truck 2 02-09-2012 08:47 AM
Truck 370, Truck 429, & Car 429 Interchangeablity??? dino Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 21 12-18-2005 11:30 PM
Anyone got better than 15MPG in a truck running a 460/429? 74crwcb429hibPS4spd 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 01-14-2003 06:11 PM
370 cid bell housing pattern ford429cu 1973 - 1979 F-100 & Larger F-Series Trucks 4 04-06-2000 03:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
