Wiper motor won't shut off - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 06-17-2003, 10:58 PM
broncr broncr is offline
broncr is starting off with a positive reputation.
I have a friend who owns a '94 Bronco and he described a peculiar problem. He can turn on his wipers normally but say's that the only way to shut them off is to turn off the engine or pull the fuse. He has adapdted by attatching a hemostat to the wiper fuse and pulls it as needed. I told him I'd throw it out here to see if anyone has a solution.
Thanks, Broncr
Old 06-17-2003, 11:19 PM
BroncoRoadKill's Avatar
BroncoRoadKill BroncoRoadKill is offline
BroncoRoadKill is starting off with a positive reputation.
My best guess would be the stop relay on the wiper moter itself.
If not then might check the switch, they can were out with age and use.
Maybe someyone knows more on this problem and will post.
Good luck.
Old 06-18-2003, 12:17 AM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
Oddly enough I used to have this problem in the rain or after extrememly wet weather and/or washing the truck. Turned out to be a leak in the windshield seal on the passenger side that was allowing water to seep down into the wiper control relay. Water conducts electricity so, water + relay contacts = nonstop wipers. Fixed the leak, replaced the badly corroded relay and PRESTO, no more perpetual wipers.
Old 06-18-2003, 01:28 AM
ba 302 ba 302 is offline
ba 302 is starting off with a positive reputation.
I had the same thing happen to me on my 1981 I turned the swich on one day and it would'nt shut off . so I took the wiper switch out of my 1986 f150 parts truck and slaped it in the bronco and I haven't had a problem since.
Old 06-19-2003, 12:42 AM
steve83's Avatar
steve83 steve83 is offline
steve83 is starting off with a positive reputation.
On the '92-96 trucks, the Wiper Control Module (behind the glove box inside the dash) is known to go bad commonly.
Old 06-21-2003, 03:25 PM
...I'll pass it on.
Wipers won't shut off Dalozsw Electrical Systems/Wiring 7 02-08-2015 08:19 AM
Wipers only work on low, won't shut off 1994 f150 4x4 1987 - 1996 F150 & Larger F-Series Trucks 6 09-05-2013 03:55 PM
Wipers will not shut off vervepipes Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 01-20-2011 01:21 PM
New Bronco - no instructions broncr Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 11-16-2003 08:45 PM
Hey Whittey broncr Ford Inline Six, 200, 250, 4.9L / 300 18 04-18-2003 01:21 PM
Tags
motor, off, shut, wiper
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
