Diesel Emissions testing issues? - Ford Truck Enthusiasts Forums
Massachusetts Chapter Join Chapter, Leader: donjamer
Old 09-19-2013, 05:53 PM
06F150CFCT 06F150CFCT is offline
06F150CFCT is gaining momentum as a positive member of FTE.
Hey guys,
I havent been on here in awhile due to the fact that these forums have turned into a very expensive obsession. Anyways, I am thinking about getting into a diesel and was curious about how strict/ridiculous it is to get one to pass. I figured stock "shouldnt" be a problem but how far into mods can you go before you the big ol' F A I L ?
So to you diesel owners, can you offer up any experience or knowledge about this? For example, is an EGR delete going to make it fail? (I know you need a tuner to turn off the dummy light) DPF delete? would they have to visually see the straight pipe in order to fail you?
I am wondering if this process is going to be like how I had to get my current 06 F150 to pass......8" lift with 37's and 20% tint.....That is all I will say. haha
Thanks for any input fellas!!
Old 09-24-2013, 06:30 PM
megawatt00's Avatar
megawatt00 megawatt00 is offline
megawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputationmegawatt00 has a superb reputation
I have an 01 F350 running DP Tuner, SS injectors, 38R Turbo, stacks with no muffler. My truck is lifted as well. When going for a sticker I make sure that I am in my modified "stock" tune to insure the smoke opacity test. Any modification to the original emissions system is grounds for failing the truck. It is best to as around to find a station that "doesn't look to hard"
I have found that if you do the mods properly and don't skimp and cut corners, make it look professional and factory and as long as it passes safety and smoke opacity you should be all set.
Old 09-24-2013, 06:58 PM
Awesome...okay, thats what I figured about finding the right station.
I appreciate the help. I think ill continue looking for a 1996 or 1997 F250 7.3 then.
1997 F150 EGR Fail code P0401 Mod#10 The Tek At Large 1997 - 2003 F150 0 09-29-2013 03:10 PM
Guide to California Diesel Smog A/Ox4 S. California Chapter 3 11-26-2012 10:04 AM
EGR Delete Tune Chrisdrm10 6.0L Power Stroke Diesel 33 08-12-2012 11:23 PM
failed emissions again f-250diesel 1994.5 - 1997 7.3L Power Stroke Diesel 17 06-15-2011 08:20 AM
VET testing conserns as well as others,.... AMT Ford Inline Six, 200, 250, 4.9L / 300 3 12-16-2001 04:58 AM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
