Winded brake lines from master cylinder to front splitter block? - Ford Truck Enthusiasts Forums
Old 09-19-2013, 01:51 PM
bbsitum bbsitum is offline
bbsitum is starting off with a positive reputation.
What kind of brake line is it and if is replicable with regular brake line? I'm just replacing long line between front and back splitter block and just would like to know what is it. What is purpose of that braiding (?) at front brake lines and why they wind down instead of going straight. Part of that long line is braided too, part that go across frame.
Old 09-19-2013, 07:41 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
The curling of the line is to allow the line to flex, the body and frame don't move the exact same way, if it was a solid straight tube it would at the very least kink at some point and at the worst break.
Old 09-20-2013, 08:35 AM
danger-ranger93's Avatar
danger-ranger93 danger-ranger93 is offline
danger-ranger93 is starting off with a positive reputation.
Also, what you're calling a "splitter block" is your HCU (hydraulic control unit, it is what enacts abs) be very very careful because if you get air in the HCU you have to have a scan tool that will go into the abs module and start the abs bleed sequence.
Old 09-20-2013, 02:11 PM
Quote:
What is purpose of that grease valve at HCU. And what is purpose of that long spring around winded brake lines? And who is psycho who design inverted flare 3/8 and bubble flare metric at another end of brake line that I replaced yesterday.
To add I do not think it is any control unit as I didn’t see any electric wire go from it. I’m not sure if I have ABS at my f 250 99 ld.
94 f250 brake master cylinder question 94f2504ever! 1987 - 1996 F150 & Larger F-Series Trucks 8 07-03-2016 01:12 AM
A question for experts Honkey Lips70 1973 - 1979 F-100 & Larger F-Series Trucks 19 01-06-2013 09:55 AM
A brake question for the experts, Honkey Lips70 1967 - 1972 F-100 & Larger F-Series Trucks 15 01-05-2013 10:45 AM
Fatigued and broke brake line/dealing with brake line-fluid splitter mOROTBREATH 1948 - 1956 F1, F100 & Larger F-Series Trucks 59 06-02-2010 08:41 PM
F6 Brake Lines at Master Cylinder rla337 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 06-15-2009 10:35 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
