Coolant question? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Coolant question?
Old 09-19-2013, 12:31 PM
camdaddy's Avatar
camdaddy camdaddy is offline
camdaddy is starting off with a positive reputation.
Coolant question?
I have an E99 that I have acquired. It currently has coolant that is not green. Based on what I have seen in other posts, Is this a problem? Should I be alarmed?
Old 09-19-2013, 03:51 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
Quote:
I'm not sure why you would be alarmed?
Since you have an E99, an OAT ELC isn't an option and neither is the hybrid OAT type coolants like the Ford "Gold" that was put in use in 2002.
Get some test strips and test your coolant, or just flush it all out and refill with some more "green" and add the proper additive since you probably don't know how old your present coolant is.
Stewart
Old 09-19-2013, 03:55 PM
Stewart_H's Avatar
You can find the flush procedure here: Gooch's Coolant Flush Procedure and In-Depth Coolant Information
Just ignore all reference to ELC and the type of coolant Gooch is saying to refill the engine with. You need to use a conventional "green" type coolant for your rig.
Stewart
Old 09-19-2013, 04:05 PM
camdaddy's Avatar
What do you do with your coolant? I'm sure there will be quite a bit...
Old 09-19-2013, 04:09 PM
Stewart_H's Avatar
Collect and recycle the drained coolant. The flush stuff I just let flow and drain.
Stewart
Old 09-19-2013, 04:23 PM
camdaddy's Avatar
Do I read correctly that it is the injector cups that dictate the coolant I have to run? Not knowing how long the "non green" coolant has been in there, are there any symptoms I need to be on the look out for? Or at least aware of?
Old 09-19-2013, 04:30 PM
Stewart_H's Avatar
Not knowing how long the "non green" coolant has been in there...
Oh crap, now I know why I was confused. I completely misread your first post. I thought you said you HAVE green coolant in your truck.
Do you know what kind of coolant it is? Do you know if the previous owner did any injector cup replacement work?
Without knowing, to be safe, if it were me, I'd flush the coolant and replace with a conventional "green" coolant.
Stewart
Old 09-19-2013, 04:47 PM
camdaddy's Avatar
Don't know the PO. I plan on flushing, but I wasn't sure if I need to be watching for anything in particular. I currently have a click or knock that can be heard clearly during deceleration. It sounds like the video Tugly posted regarding an bad injector when at idle. http://www.ford-trucks.com/forums/12...hing-else.html However, I have been searching for why it make a click during the deceleration (injectors off). While searching for an answer, I came across the coolant "issue". I still can't figure out the click/knock noise.
Old 09-22-2013, 07:55 PM
rufushusky's Avatar
rufushusky rufushusky is offline
rufushusky has a great reputation on FTE.rufushusky has a great reputation on FTE.rufushusky has a great reputation on FTE.rufushusky has a great reputation on FTE.rufushusky has a great reputation on FTE.
What color coolant is in the truck currently? Some pre-charged conventional coolants, basically "green" coolant with SCA's already in it, are different colors... purple, blue etc. Which your E99 would be fine with.
As far as ELC in an early 99 IIRC it is the sealant used on the injector cups isn't ELC friendly. Suffers the same fate as the as the sealants used on 90s GM engines when they first introduced Dex-Cool. Dex-Cool is a OAT based coolant, like ELCs, that uses 2-EHA (that many ELCs do as well) which will eat some sealants and gaskets.
Old 09-22-2013, 08:52 PM
camdaddy's Avatar
I would say that it's gold. I have a picture, how would I go about posting it?
Contaminated coolant after service sgrol 6.7L Power Stroke Diesel 3 09-30-2014 08:54 AM
coolant and temp 96 psd 63ferd 1994.5 - 1997 7.3L Power Stroke Diesel 6 05-22-2014 02:03 AM
Coolant Options for the 6.0 Subzero68 6.0L Power Stroke Diesel 19 12-18-2013 09:30 PM
coolant leak with in unknown part WHTTLHNTR 6.0L Power Stroke Diesel 10 11-09-2013 08:54 PM
Changing the coolant...How to? 01' Super Crew 1997 - 2003 F150 1 03-06-2003 10:26 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
