distribater - Ford Truck Enthusiasts Forums
distribater
Old 09-18-2013, 01:00 PM
dwingalls dwingalls is offline
dwingalls is starting off with a positive reputation.
Question distribater
the manual said the rotation of the distribater is clockwise but my 1997 7.5 rotates counter clockwise. is Haynes book wrong or is my engine whered?
Old 09-18-2013, 04:01 PM
BradyCouchman's Avatar
BradyCouchman BradyCouchman is offline
BradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud of
a 460 distributor rotor will rotate Counter Clockwise
4.9l firing order Ringwood1 1987 - 1996 F150 & Larger F-Series Trucks 19 11-15-2016 07:31 AM
Timing issue chesster51 1987 - 1996 F150 & Larger F-Series Trucks 12 10-25-2016 06:15 AM
Distributor Rotation Changed coopster17 1961 - 1966 F-100 & Larger F-Series Trucks 8 08-15-2016 09:37 PM
351w oil pump will not rotate to prime rustoleum82 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 07-04-2016 08:41 AM
Timing Issue lm987 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 10-19-2015 07:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
