tow mirrors
Soak it in PB Blaster or Kroil. Remove the inner panel and see if you can grab the remainder of the bolt where it sticks into the door cavity. Try turning it with a vise-grip. You might get lucky and thread it out, and be able to reuse the rivnut.
Was this one of the lower bolts in the middle of the door, or one of the upper ones up by the window?
I'd start by trying to grab what's left with a vise-grip. Again, soak in a penetrant. Heat with a torch after the penetrant dries away. Those easy-outs tend to break off in hard steel bolts. Drilling the hole for the easy-out is a PITA, as well.
Might even work to grind a slot in the protruding stub, if you have a cutting wheel that will fit in there, and turn it with a screwdriver.
But yeah, good point about whether it's a bolt; look at the other mirror, and confirm that it's a bolt going into a threaded insert in the bracket, and not a stud coming out of the bracket and a nut. I sold our four-leg mirrors a few years ago, and I forget which way it was. If it's a stud, you're probably looking at a new mirror head.
Yes. Grind what is left of the bolt flush with the neck. The center punch and drill it out(use drill press if you got it) and retap it. Use ALOT of anti-seize when you put it back together
