Compression test on 6.9 IDI (84 F350)
I have some new glow plugs and thought while I was at it, why not check compression. I got the plugs out (thankfully they were Beru, maybe the originals) using a 1/4 ratchet, 6" drive and a 10mm socket.
It's looking like I have to remove the fuel lines to get the compression tester in place (it's much thicker than the 1/4" extension bar). Is removing the fuel lines SOP for testing compression on these 6.9's? Anything I need to know before taking the lines off (other than not bending them)? Are they pressurized, if so how do I pressurize them?
I don't think removing the hard lines is SOP for a compression test, but if it makes your life easier, go for it.
The pictures I've seen make it look like the best thing to do is disconnect all the hard line connections at the injection pump and at each injector, and lift all the hard lines off the engine as a unit (leave the rubber vibration dampers attached to the lines). That will ensure that everything's lined up correctly when you go to replace the lines later, and should minimize any accidental bending.
No, the lines won't be pressurized when the engine isn't running. You might get some fuel out of them when you take them off, but nothing to worry about.
Direct Indirect Diesel Engine Compression Injection Tester 12pc Test Kit Gauge | eBay
I didn't see a 90 degree angle adapter, but will check again. pretty sure I won't be getting the hose routed in between the hard fuel lines over a couple of the glow plugs. Maybe I can bend the rubber hose under and around the hard lines.
Still, if the cold test is close to being within tolerance then I will go ahead with replacing the injectors, return lines, and probably the IP as I hear it's best to do that at the same time as the injectors. I'll probably also pull off the middle pan and replace one or more lifters. If compression is way out of synch I'll probably just put the new glow plugs/controller/relay on and let it go for a while.
No way I can get the compression tester hose over a couple glow plug holes wihtout removing the fuel spider.
I went ahead and ran a check on the front right cylinder just for kicks. Let it cycle ten times with a battery charger attached. Got out to see the guage read 375 PSI. Test was done cold. I was going to try another hole that's easy to get to, but I can't get the guage to reset. There's a schrader valve on the hose, but pressing it in fully does nothing. It's stuck on 375.
I just tried tapping it on the vice.. no luck. I also tried holding in the schrader valve while tapping, nothing there either. Chinese junk. Couldn't even use the damn thing more than once.
Might try removing the valve core all-together and see what happens, could be a bad core but i doubt it.
I got the Harbor Freight one ($110 on sale with 20% coupon).
I cannot get to the glow plug holes with the 90 degree angle connector in the HF kit unless I loosen the fuel lines. Even then it's hard. I thought it wouldn't be a bad idea to pull them off, since I'll be replacing the injectors soon anyway. May pull the cover so I can get to the lifters (one ticks loudly).
Question, how the **ll are ya'll removing the bottom-most fuel line nuts on the IP? I could barely get the second from the bottom nuts loosened. Using a flare wrench just no room to turn it (wrench sandwiched between manifold and IP).
