So my truck is a 1986 F150 regular cab long bed 2wd with the 302 and 3.55 Non-LS rear end. Now i'm interested in the idea of beefing up my rear end, I'd like to go with a 3/4 rear end with 4.10 gears and getting leaf springs for an f250 to help increase my load capacity. Any thoughts, tips or alternative ideas are welcome,
You'd have 8 lug wheels in the rear. The 8.8 is a pretty stout rear, the frame on the 150 is thinner so it's questionable how much extra load you can carry. You can get 4.10 gears to install into the 8.8 if you want.
Amen. A slight upgrade that keeps the 5-lug axles would be to go with a 9". But probably not worth it as the 8.8 will stand up to reasonable abuse behind that engine.
I would change the ratio in the 8.8 and get some helper springs. You have to consider the front brakes do most of the stopping and they arent rated for that much of a heavy load. The 8.8 open rear ends are pretty stout. The LS variety not as. Maybe you are just ready to step up to a 3/4 ton.
How much are you planning to tow? You need to consider that a vehicles payload capacity is determined by many things, not just axle load capacity. Your braking system and spring rates largely dictate how much you can safely haul.
Also, many people may disagree with me on this but IMO the 8.8 is a superior axle in comparison to a factory spec 9".
Alright thanks for the advice guys, it seems like the best option is just get helper springs and gears. I'm planning to run 33s in the future so I'm just looking to beef up my rear end. Now what all axles can I pull 4.10s out of and have them be a straight swap into my axle?
