How do I fix this fuel leak? - Ford Truck Enthusiasts Forums
Old 09-17-2013, 12:45 PM
jayro88 jayro88 is offline
jayro88 is gaining momentum as a positive member of FTE.
So I got my van running again. While doing this I noticed I was dripping diesel when it was left running. Digging into it I found I was leaking fuel from here. It is circled in yellow:
Has anyone else had an issue with fuel leaking from here and is so how did you fix it?
Thanks
Old 09-17-2013, 01:07 PM
Dark Horse's Avatar
Dark Horse Dark Horse is offline
Dark Horse is starting off with a positive reputation.
Check this thread for detailed Info:
http://www.ford-trucks.com/forums/85...ns-w-pics.html
Mark
Old 09-17-2013, 01:16 PM
Mark
Thanks. Looks like my next project will be replacing the fuel heater. I would just do the o-rings, but with my luck it would still leak.
Old 09-17-2013, 03:21 PM
tjc transport's Avatar
tjc transport tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
why not just remove it and put a pipe plug in there?
you really do not need the fuel heater unless you are up near the arctic circle.
Old 09-17-2013, 03:28 PM
Nibor Nibor is offline
Nibor is starting off with a positive reputation.
I just put a pipe plug in 2 of mine a few weeks ago - 1/2" npt tap - plug it and I also did some jb weld for good measure
Old 09-17-2013, 04:06 PM
That is kind of what I was thinking. Just didn't know if I would have any issues with cold temperatures. We usually get a few sustained single digit (below zero at night) times during the winter. The van is parked outside, would I need to worry about it?
Old 09-17-2013, 04:33 PM
i ain't rite
my 88 has had the heater disconnected since it burned out back around 1990. never had any fuel gelling problems with it, and we get below zero temps here quite often. all i do is split a quart of diesel kleen between the fuel tanks when i fuel it up.
Old 09-17-2013, 10:58 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
yeah just jb weld it.
if you want a fuel filter heater,consider installing a coolant filter and wrapping the two filters together to kill two birds with one stone,or buy a universal heater blanket.there's no need to tell ford it's ok to charge what they want for that old heater by supporting them with those ridiculous prices.example:
https://www.utahbiodieselsupply.com/...lterheater.php
Old 09-17-2013, 11:01 PM
Macrobb's Avatar
Macrobb Macrobb is offline
Macrobb is gaining momentum as a positive member of FTE.
Personally, I just disconnected it, cleaned the area, and filled the connector with super glue. Once it set(took /ages/), I haven't had any issues. This was over a year(year and a half?) ago.
Old 09-19-2013, 01:39 AM
speedwrench72's Avatar
speedwrench72 speedwrench72 is offline
speedwrench72 is starting off with a positive reputation.
IMO to keep it original, the filter head on the 7.3 is the high point of the system, and the return line leaving the filter head has a check valve, and small orifice in it, that when the engine's lift pump is operating a small amount of fuel is always returning to the tank, taking bubbles from tank slosh, with it down the return line's cooling the injectors along the way, the return line leaving the ip never seams to have anything coming out of it when I pull the hose off and look at it. the check ball is plastic and has a ultra lite spring that will get lost very easy if you remove the fitting and aren't ready to catch it. some persons have said that ford put out a tech bulletin that one could omit the return line from the filter head, I have not seen this bulletin, IMO to leave it hooked up. or the only way for air to get out of system is out the injector line's. The check valve should keep the filter from emptying out, when sitting. when the o ring in the heater rots it lets air in the filter head..
Old 09-19-2013, 11:20 AM
i ain't rite
Quote:
when it works as it should. but they very rarely work as they should. that is why ford issued the TSB back in 1989 or 1990.
Old 09-19-2013, 09:31 PM
Macrobb's Avatar
Oh, that explains why a fuel bulb/check-valve, put inline, solves all these problems... It *should* have had one from the factory, but by now it's gone/broken!
Old 09-19-2013, 11:07 PM
Quote:
yeah.
Self-priming with a 10 ft. minimum lift
Transient Protection
Check valve
4 hour dry run
Self-regulating
33 - 50 GPH
15 - 9 PSI
VCA approved EC 95/54
State-of-the-Art Electronic
Sealed Electronics
Reverse Polarity Protection
Corrosion Resistant over 100 hours salt spray
Durable Transparent fuel bowl
Light Weight - 3LBs at 7 1/4
Low Power Requirements 1.4 amp on average
Operating Temperature Range: -40F to 180F
'88 E250 Cup Holder Project jayro88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 19 02-15-2016 05:23 PM
'88 E250 Air Dam Project jayro88 1968-2013 Full Size Vans 21 05-26-2015 04:49 PM
E250 6.0L Trans Cooler Install jayro88 1968-2013 Full Size Vans 0 08-02-2014 10:59 PM
e250 6.0 Trans Cooler install jayro88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 08-02-2014 08:06 PM
E250 Gauges Installed, now no rear AC/Heat fan jayro88 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 08-20-2013 09:07 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
