Questions about a 1964 F-100 warranty tag
Hi all, new member with a new to me 1964 F100. Been lurking the last couple of weeks but just finally joined and paid my dues.
Hopefully I can get some information decoded from the warranty tag:
F10CR512888
W.B. 114
Color J
Model F100
Body 181
Trans G ( could be a 6 )
Axle 12
Max GVW 500
Cert Net HP 135
RPM 3800
DSO 710779
Truck was purchased without motor or trans.
Looks to have either factory or dealer installed power steering.
Thanks to all in advance for any help.
F10CR512888
W.B. 114
Color J
Model F100
Body 181
Axle 12
Max GVW 500
Cert Net HP 135
RPM 3800
DSO 710779
Hopefully I can get some information decoded from the Warranty Plate:
F10CR512888 / W.B. 114 / Color J / Model F100 / Body 181 / Trans G / Axle 12 / Max GVW lbs. 5000 / Cert Net HP 135 / RPM 3800 / DSO 710779
F10 = F100 2WD
C = 292 2V
R = San Jose CA Assembly Plant.
512888 = 1964, assembled March 1964.
114" Wheelbase.
J = Rangoon Red.
F100 2WD, 5,000 lbs. GVWR
181: 1 = Light Gray Crush Vinyl & Light Gray Rib Vinyl / 81 = 81A Standard Cab.
G = FX Cruise-O-Matic.
12 = Ford 9" Rear Axle / 3.89-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
135 net HP @ 3,800 RPM
710779:
71 = Los Angeles (SoCal) Ford District Sales Office, where the original selling dealer ordered the truck from.
0779: Domestic Special Order number. Truck special ordered by original purchaser, not "bought off the lot."
P/S would have been a dealer installed kit. No trans code of 6, so it has to be a G.
Texas_Doug
07-13-2014 12:44 PM
pupcar
05-15-2014 10:18 PM
Pixleyyy
08-13-2013 09:55 PM
Treysoldford
07-20-2011 08:59 PM
strong17
05-05-2009 05:25 PM
