Smog test with EGR delete in Nevada - Ford Truck Enthusiasts Forums
Old 09-16-2013, 07:03 PM
Wayne Eady's Avatar
Wayne Eady Wayne Eady is offline
Wayne Eady is starting off with a positive reputation.
I just moved to Nevada and have had an EGR delete. Will it pass inspection like this? If not what do I do?
Old 09-16-2013, 10:10 PM
MisterCMK's Avatar
MisterCMK MisterCMK is online now
Avid Winter Hater
MisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputationMisterCMK has a superb reputation
What does the smog test consist of in Nevada?
Old 09-16-2013, 10:44 PM
mustang_309's Avatar
mustang_309 mustang_309 is offline
mustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to behold
Quote:
It depends on how the EGR was deleted, if the EGR cooler was completely removed it won't pass the tampering law, if it has the stealth delete ( EGR cooler gas pass plugged at both ends ) you will be fine. You need to see if the EGR valve is even still there. Worst case scenario you will have to return the truck to stock by having the EGR cooler and EGR valve reinstalled if they were removed.
Old 09-16-2013, 10:53 PM
Wayne Eady's Avatar
Where would I look for the cooler and valve?
william_04_x's Avatar
william_04_x william_04_x is online now
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
Here in Vegas they do a visual, and dyno test. The vehicle goes on the rollers, probe in the pipe, and they'll mildly get it up to 45mph or so. As long as you aren't blowing clouds of smoke, it'll pass the sniffer test. When it comes to the visual, most smog techs have no idea what they're looking at. They will check for a cat, fuel cap, and glance under the hood. I had my nitrous system installed, and still passed. lol
Old 09-16-2013, 10:57 PM
BLADE35's Avatar
BLADE35 BLADE35 is online now
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Quote:
YES
That Nitrous just helps them burn Cleaner don't it LOL
Old 09-16-2013, 10:58 PM
Wayne Eady's Avatar
William, where did you go? I live near a Jiffy Smog and was thinking of going there.
Old 09-16-2013, 11:10 PM
Wayne Eady's Avatar
Old 09-16-2013, 11:16 PM
POORBOY1964's Avatar
POORBOY1964 POORBOY1964 is offline
POORBOY1964 has a good reputation on FTE.POORBOY1964 has a good reputation on FTE.
Old 09-16-2013, 11:23 PM
olfordsnstone's Avatar
olfordsnstone olfordsnstone is offline
olfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to beholdolfordsnstone is a splendid one to behold
There are counties in Nv that do not require smog inspections.
Old 09-16-2013, 11:53 PM
Wayne Eady's Avatar
Quote:
Originally Posted by POORBOY1964 View Post
Thanks, very helpful. I'll have to look in the morning.
Old 09-16-2013, 11:54 PM
Wayne Eady's Avatar
Quote:
I live in Las Vegas. Clark Co.
Old 09-17-2013, 12:08 AM
Randy777 Randy777 is offline
Randy777 is starting off with a positive reputation.
I have the EGR delete and get my smog done at a smog station next to the Emerald Casino in downtown Henderson. I have done probably five or six smog checks on my truck there and never had a problem. Most of these guys are only concerned that you pass the sniffer check and check your gas cap and exhaust.
Old 09-17-2013, 12:11 AM
VQT VQT is offline
VQT has a great reputation on FTE.VQT has a great reputation on FTE.VQT has a great reputation on FTE.VQT has a great reputation on FTE.VQT has a great reputation on FTE.
There is a place in North Las Vegas on Nellis across from the AF Base charge less than other smog places.
Old 09-17-2013, 12:27 AM
The on in Henderson is Forty bucks
Nevada's October BS Thread 67 Olfthfl Nevada Chapter 160 10-31-2015 01:52 PM
New guy here from NV asking for a reccomendation pffpjoker 6.0L Power Stroke Diesel 5 08-03-2015 04:41 PM
Nevada "Happy New Year 2015" Thread 67 Olfthfl Nevada Chapter 154 02-01-2015 03:21 PM
egr and oil cooler replacement cost allons 1999 to 2016 Super Duty 0 02-02-2014 12:27 PM
EGR delete or EGR block? brkncly 6.4L Power Stroke Diesel 3 08-02-2012 09:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
