Smog test with EGR delete in Nevada
Old 09-16-2013, 06:03 PM
Wayne Eady's Avatar
Wayne Eady
Wayne Eady is offline
I just moved to Nevada and have had an EGR delete. Will it pass inspection like this? If not what do I do?
Old 09-16-2013, 09:10 PM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
What does the smog test consist of in Nevada?
Old 09-16-2013, 09:44 PM
mustang_309's Avatar
mustang_309
mustang_309 is offline
It depends on how the EGR was deleted, if the EGR cooler was completely removed it won't pass the tampering law, if it has the stealth delete ( EGR cooler gas pass plugged at both ends ) you will be fine. You need to see if the EGR valve is even still there. Worst case scenario you will have to return the truck to stock by having the EGR cooler and EGR valve reinstalled if they were removed.
Old 09-16-2013, 09:53 PM
Wayne Eady's Avatar
Wayne Eady
Where would I look for the cooler and valve?
william_04_x's Avatar
william_04_x
william_04_x is online now
Here in Vegas they do a visual, and dyno test. The vehicle goes on the rollers, probe in the pipe, and they'll mildly get it up to 45mph or so. As long as you aren't blowing clouds of smoke, it'll pass the sniffer test. When it comes to the visual, most smog techs have no idea what they're looking at. They will check for a cat, fuel cap, and glance under the hood. I had my nitrous system installed, and still passed. lol
Old 09-16-2013, 09:57 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
YES
That Nitrous just helps them burn Cleaner don't it LOL
Old 09-16-2013, 09:58 PM
Wayne Eady's Avatar
Wayne Eady
William, where did you go? I live near a Jiffy Smog and was thinking of going there.
Old 09-16-2013, 10:10 PM
Wayne Eady's Avatar
Wayne Eady
Old 09-16-2013, 10:16 PM
POORBOY1964's Avatar
POORBOY1964
POORBOY1964 is offline
Old 09-16-2013, 10:23 PM
olfordsnstone's Avatar
olfordsnstone
olfordsnstone is offline
There are counties in Nv that do not require smog inspections.
Old 09-16-2013, 10:53 PM
Wayne Eady's Avatar
Wayne Eady
Originally Posted by POORBOY1964
Thanks, very helpful. I'll have to look in the morning.
Old 09-16-2013, 10:54 PM
Wayne Eady's Avatar
Wayne Eady
I live in Las Vegas. Clark Co.
Old 09-16-2013, 11:08 PM
Randy777's Avatar
Randy777
Randy777 is offline
I have the EGR delete and get my smog done at a smog station next to the Emerald Casino in downtown Henderson. I have done probably five or six smog checks on my truck there and never had a problem. Most of these guys are only concerned that you pass the sniffer check and check your gas cap and exhaust.
Old 09-16-2013, 11:11 PM
VQT's Avatar
VQT
VQT is offline
There is a place in North Las Vegas on Nellis across from the AF Base charge less than other smog places.
Old 09-16-2013, 11:27 PM
Randy777's Avatar
Randy777
Randy777 is offline
The on in Henderson is Forty bucks
Quick Reply: Smog test with EGR delete in Nevada
