Low compression cylinder question - Ford Truck Enthusiasts Forums
Old 09-16-2013, 04:08 PM
LloydB's Avatar
LloydB LloydB is offline
LloydB is starting off with a positive reputation.
Hello all, purchased my 66 a few months ago and diving in to several issues I've run into.
The truck has a '73 351W that's running rough at idle like one spark plug is weak/unplugged.
I have already installed new plugs, wires, coil, cap and rotor.
Can't set/check the timing cause there's no timing indicator tab. Still trying to figure out what it should have. It doesn't ping and has decent power, so I think timing is pretty close.
I checked compression and got between 127 and 140 on all cylinders except number one, which was 62.
I added about a tablespoon of oil to the cylinder, tested again and it came up to 90.
I've read several post about stuck compression rings as a possibility and a burnt valve, worn cam lobe, bent valve, or bent push rods being a cause.
The engine doesn't smoke at all, leading me to think it's not the rings.
Anyone had any similar experiences and suggestions for further testing?
My initial thought was pulling the heads for valve job, then replacing the cam and lifters, but hate to do that and have bad rings haunt me later on.
Old 09-16-2013, 06:11 PM
TA455HO's Avatar
TA455HO TA455HO is offline
TA455HO is gaining momentum as a positive member of FTE.TA455HO is gaining momentum as a positive member of FTE.
Probably the next test without any major disassembly to do would be a leak-down test. With a leak-down test you put compressed air into each cylinder one at a time and rotate through the four cycles and it can help isolate what is wrong. If air comes up through the carb or out the exhaust pipe when at TDC then valves are suspect. If air comes out the oil fill tube or vent then valve seals are likely suspect. Anyway, that's what I would try next if it were me.
Low compression and rough idle 86stepsideF150 Ford Inline Six, 200, 250, 4.9L / 300 32 02-23-2017 10:44 AM
1999 7.3 Stuck Valve, Blown Rings, or Scored Sleeve...let's find out! Glowplugger 1999 - 2003 7.3L Power Stroke Diesel 35 12-06-2016 06:27 AM
02 Expedition 4.6 problem I can't figure out... Galen717 1997-2006 Expedition & Navigator 10 06-21-2016 03:52 PM
Most confusing diagnostic ever..... cyclone-429 1957 - 1960 F100 & Larger F-Series Trucks 4 01-30-2015 05:39 PM
how do i tell if its the rings or valves making low compression dufrain Ford Inline Six, 200, 250, 4.9L / 300 2 08-30-2003 08:27 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
