starting problems
Plugging it in warms the oil, the injectors are fired by oil so thick oil will delay the poppet from opening fast retarding the timing. The clearances under the poppet are more than likely wore out. Could be part of the problem. Also you could have a plunger issue in the injector causing poor atomization.
Matt knows these injectors..listen to what he has to say.
Also...
Check voltage drop acrosss the solenoid? Just because its new dosent mean its good. also valve cover connections for burnt pins? Power wire from supply to solenoid and to the vcs..voltage drop test will be your friend and will get you to your cure the fastest
Also...
P Eames
02-15-2003 10:44 PM
