Well, I went and did it....
#1111
Well, we took the maiden voyage with the new camper this weekend. It was a short trip (distance wise) so it was a good shake down for the new setup. And it's a good thing I did too. The truck runs great. Power is very good, but boost is still sluggish and EGTs are high. I must have a boost leak somewhere. I was able to push close to 20 PSI with this setup before I installed the IC and now, it seems 15 is about the most I can muster. I was also seeing 1100 degree EGTs. Something is amiss... I had a cap on the little boost line fittings on the Spider and one of the caps blew off (I'm not surprised), so I'll pull the spider, drill and tap for threaded plugs in those two locations, then put the air pressure to it again and try to determine where I'm losing pressure. I'm not sure what else to do at this point. Aside from that issue, I think this setup is going to work well for me. The ZF does a great job of putting the power down even through the 3.55 read gear set. The gearing is low for towing, but at 55-60 MPH all you need to do is drop a gear and carry 4th and power isn't an issue.
And just because we all like pictures, here are a few from the weekend.
#1115
#1118
It's a great place to go and we always have a great time. The place we camp isn't really a real camp site, this is just a "Family Camp" on Memorial Day and Labor Day put on by the church camp that our church supports. It is a great place to be and we camp with about 4 other families that we are always next to. Between the 5 families there are 16 kids, so it's a lively time! It's a lot easier now that the kids are older and don't require as much oversight. This past weekend was as close to being perfect as they come. The weather was great, and we had a really good time. Back to reality now, but we're already planning the next couple camping trips.
Glenn, what would you know about "going back to work"!?
I know you did that for a whole lot of years, but now you're living the good life! Then again, everybody that I know who is retired says that they're as busy or busier now than when they were working...
#1120
#1121
When I was still working a lady said to me, "if you have anything that you have to get done, do it now because after you retire you will not have time to do it"! I looked at her like she was crazy, haha
#1122
Yeap, Glenn doesnt know what he said.
We that are still working we know what are you talking about Nate
#1123
#1125
One was started a while back....https://www.ford-trucks.com/forums/1...ping-pics.html
