Well, I went and did it....
#91
Any parts stire in the "help" section.
get the correct kit there.there are several options.
pull the panel and disconnect wiring and pull out as you pull door off of the hinges.rebuild.rreinstall door.do not try to pull pins with door bolted on and rebuild that way.unless you want to repaint.
#92
Man Bill, I am right there with you!
Nate, looking good! Question, what are those two **** looking things to the right of the message center? Also, um, do you like those bigger tow mirrors? If not, lemme know and I would be down to swap with you!
I think you got a a really good deal with the new truck! Stoked for you!
Another piece of advice is to leave the part of the hinge that bolts to the truck ON THE TRUCK if you can. It's easier to do this in a vice, but lining the hinges back up with the door hanging on the truck is next to impossible. If you do take that part off, make sure you mark around it well so you can get it positioned correctly again on re-assembly. There's a lot of adjustment in those three bolt and it takes FOREVER to get it right if you didn't mark it first (don't ask me how I know this...) If you have a die grinder you can get the pins out easily enough with them on the truck. Or you can reach in there and cut the pin in half in the center of the hinge.
#93
I made some good progress this weekend. I got a lot of the little odds and ends wrapped up inside the truck and got the wheels and tires swapped over from the old truck.
Slowly but surely I'm whittling away at the "to do" list. I have added some things to it this weekend though. The glow plug relay is toast, making it start hard even in the 50 degree weather we had this weekend. I think a Stancor is in order.
I fixed a small fuel leak too by plugging the port where the Fuel Filter Restriction sensor used to live, it was dripping.
I had to tear the driver side door all apart again to get the driver side speaker working. BOTH the wires for the speaker were broken inside the flexible section of the wiring harness between the door and the cab. New wires were soldered in and it works great now. I am rather impressed with the audio quality of the "premium sound system" as compared to the more or less terrible stock speakers that were in the other truck.
I found a small boost leak between the manifold and one of the up-pipes and was able to tighten the bolts up and I think it will be good now. You don't get that on a NE Ohio truck, lol. Lots of other odds and ends happened as well, but these were the bigger things.
Also, I have no reverse lights or 4x4 indicators and when I crawled under there I see no wiring harness whatsoever going to the transmission. In fact, there is a 2 wire connection going into the T/C that has a plug and about 2" of wire hanging on it and that's it. I don't know what exactly happened there. Does anybody know where the ZF5 wiring harness is supposed to originate? I will have to look and see if there is a chance I might have one in my loft.
The truck is at the dealership today to get the cruise control and CPS recalls done. It needs the air box recall done too since it has the one with the square holes in it, but the dealership didn't show that one for my VIN and since the truck will be getting a 6637 anyway, I didn't push the issue.
#96
#98
I'm curious what it would have been. I already have the Stancor ordered though. I know a lot of guys use either a GPR109 from NAPA (which is what I did on the last truck) or a snow plow relay. I figured I may as well do it once and be done this time around.
#99
#100
#101
#102
#103
I purchased it when I was having issues when it got really cold (50's-60's) 2 years ago. but by the time it got here the temps had warmed up and I put it in the box with my tow straps under the back seat.
It's still there....
Richard
#104
#105
On Edit: Talked to the dealer. they show no recall and no records of anything except an extended warranty being purchased. Oh well. She told me it may have expired, but most likely the time period for the build date did not include that particular recall. Hmmm....hope she doesn't burn!!!!
