Newbie 85 f250 frame off resto (Image Heavy) - Ford Truck Enthusiasts Forums
Old 09-16-2013, 10:09 AM
Piston Honda's Avatar
Piston Honda Piston Honda is offline
Piston Honda is starting off with a positive reputation.
A little history of the truck. The truck was a farm truck for the first 18 years of its life, so it's been worked. 88,000 original miles but looked like 388,000. My father inlaw bought it and let it sit like all of his other vehicles. He needed a place to park it, so it ended up in my yard. I used this truck when going to the dump and picking up material while renovating my house about six or seven years ago. I was driving it in a snow storm approaching a red light when the brake pedal went to the floor. So with no brakes there it sat for a year until he came and brought it to his new residence. It sat again until june of this year. I was looking to buy a truck when he suggested that i put some work into the 85. I knew this truck needed a ton of work and was reluctant to try and fix it. I had never attempted this much work to a vehicle. The price was right so I decided to bring her back to life!
I have begun assembling the chassis and have taken quite a few pics along the way. I'll post a few a day to get everyone up speed if anyone is interested in seeing a newbie trying his hand at a frame off.
Old 09-16-2013, 10:49 AM
str8sixman's Avatar
str8sixman str8sixman is offline
str8sixman is starting off with a positive reputation.
ill gladly watch this one! ive been waiting for a good time/money situation to do something like that to mine
Old 09-16-2013, 10:58 AM
Old 09-16-2013, 11:03 AM
JGreen236's Avatar
JGreen236 JGreen236 is offline
JGreen236 is starting off with a positive reputation.
Looks good, what was your process on getting the bed bolts off?
Old 09-16-2013, 11:25 AM
Grubbworm's Avatar
Grubbworm Grubbworm is offline
Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.Grubbworm has a great reputation on FTE.
Subscribed.
Old 09-16-2013, 11:44 AM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Subscribed.
Old 09-16-2013, 11:46 AM
Quote:
Thanks! Two people, one under the bed one on top. I took a dull chisel and hit the high spots around the top of the carriage bolts and grabbed them with vise grips and heated nuts with mapp gas. They all came out no problems surprisingly. The bottom bed panels are toast so I wasn't worried about damaging them.
Old 09-16-2013, 03:38 PM
Pronk Pronk is offline
Pronk is starting off with a positive reputation.
Subsribed.
What are your plans for the frame?
Old 09-16-2013, 03:59 PM
nikmish's Avatar
nikmish nikmish is offline
nikmish is gaining momentum as a positive member of FTE.nikmish is gaining momentum as a positive member of FTE.
fun! give us more
Old 09-16-2013, 04:06 PM
Quote:
Originally Posted by Pronk View Post
Subsribed.
I wire wheeled the whole frame and took a portable sand blaster to all the tight spots, cleaned and prepped using por 15 products then I put two coats of black por15. I did the same on the axles and som other misc pieces. I plan on going over the por with some tie coat primer and then two coats of topcoat.
Old 09-16-2013, 04:49 PM
Quote:
Originally Posted by nikmish View Post
fun! give us more
I was only planning on releasing a few photos a day, but, alright here's some more
After you use the prepping spray it flash rusts but from what they say it helps the paint bond
...and some paint
Old 09-16-2013, 05:19 PM
4x484150's Avatar
4x484150 4x484150 is offline
4x484150 has a good reputation on FTE.4x484150 has a good reputation on FTE.
Quote:
In case you couldn't tell, we love pics here! The frame looks great.
Old 09-16-2013, 05:38 PM
Quote:
Thanks a lot! It came out alright, but it dried weird and seems flat in some areas and glossy in others. The paint is kind of hard to work with. That's why I have decided to topcoat after all leaf springs and ubolts are installed.
Old 09-16-2013, 05:49 PM
JGreen236's Avatar
I can't wait to do a frame off restoration on mine. How much money do you have in paint on the frame(estimate)? And is that a 351w HO you've got?
Old 09-16-2013, 06:06 PM
Well, I haven't put the tie coat or topcoat on yet, so without that about $165. I still have 1 1/4 quarts left for underside of cab, bed and trans.
Not a HO just a reg 351w.
Another $50 for the marine clean and prep & ready
Let me tell you a story... FoxFord33 Ranger & B-Series 2 01-22-2017 12:58 AM
F150 Resto (Grandpas 85) Chevra 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 10-24-2016 02:41 AM
Contemplating 1972 F6/700 Dump Purchase 94150 Large Truck 10 02-12-2016 01:18 PM
Newbie rockhardplace011 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 11-03-2015 01:24 PM
Alert Incoming New Guy skyde 1957 - 1960 F100 & Larger F-Series Trucks 12 04-22-2015 08:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
