Newbie 85 f250 frame off resto (Image Heavy)
#136
#138
#140
Edelbrock said that manifold is a direct replacement for the 4V HO manifold. That being the case the exhaust gas comes up through that hole and into the EGR valve itself. Lots of guys on here have made block off plates with everything from a Coke can to stainless steel sheet. You will need a gasket on the manifold, your block off plate, another gasket, and then the carb. And the bottom gasket has to fully cover the hole, as does the plate.
#141
#142
#143
I tried sliding the mech pump in the timing cover today and it doesn't seem to want to go in. Any tricks?
#144
There are potential for leaks, but it can and does work. You might find a commercial block off plate that is less likely to leak.
The arm on the pump is hitting the actuator cam and you are compressing the spring in the pump as you tighten the bolts down. Turn the engine half a turn or so and see if it gets easier. There are points in the engine's revolution where the arm is just barely compressed and places where it is highly compressed - which is where you probably are.
#146
Thanks! I'm at a point where everything seems to be giving me trouble right now
#147
#149
I found a spacer to use with the installation tool and I'm trying to get the harmonic balancer on I think it's all the way on but the pulleys don't seem to line up correctly.
I measured the depth of the stub on the back of the balancer and I don't think it can go in any more. Why don't the pulleys line up? Am I missing something?
