Newbie 85 f250 frame off resto (Image Heavy) - Page 9 - Ford Truck Enthusiasts Forums
  #121
Old 02-19-2014, 09:48 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is offline
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Bummer! What brand are the headers?
  #122
Old 02-19-2014, 10:11 PM
Piston Honda's Avatar
Piston Honda Piston Honda is offline
Piston Honda is starting off with a positive reputation.
Quote:
Hooker competition headers 6912-HKR
The directions says that it fits 80-95 f150, f250, f350 2wd and 4wd. The front axle came from a 89 f350. The frame from a 85 and 89 is the same, correct? So I don't know how they don't fit.
  #123
Old 02-19-2014, 10:17 PM
Gary Lewis's Avatar
The frame is different between 85 and 85 at least where the bumper mounts, but I don't know if there are other changes.
  #124
Old 02-19-2014, 10:24 PM
Hmm...there must be other changes besides the bumper mounts. When I got my leaf springs I got ones for 89 f350, so there isn't many things that could be different there....
  #125
Old 02-20-2014, 07:24 AM
f150xltlarait f150xltlarait is offline
f150xltlarait is starting off with a positive reputation.
I have the 44hd but mine look like about the same clearance wise ill measure them and get back to you
  #126
Old 02-20-2014, 12:55 PM
BiGGreen350's Avatar
BiGGreen350 BiGGreen350 is offline
BiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant futureBiGGreen350 has a brilliant future
incorrect, other than the swiss cheese frames in 80 and 81, the frames are the same from 80-91,
in 87 they began using brackets on the bumpers that mount to the side of the frame horns instead of bolting through the fronts like the 80-86 but frames are the same,
they changed drastically horn wise when 92 rolled around with the obs, here is a link showing 87-91 bumper and brackets
towards the bottom is the post with the pic of the brackets
http://www.ford-trucks.com/forums/12...ocation-2.html
  #127
Old 02-20-2014, 01:32 PM
Gary Lewis's Avatar
Matt - Thanks for that clarification. I sit corrected.
  #128
Old 02-20-2014, 01:47 PM
Well that's good to know. Now I really wonder why they don't fit. I sent them back this morning, and ordered some Flowtech ones, hopefully these ones fit better.
  #129
Old 02-20-2014, 01:49 PM
no problem gary
I went through trying to find that info out when exploring different ways to compensate for the body lift gap
  #130
Old 02-20-2014, 11:02 PM
Alright, the gas tank is in, brake lines are done, driveshaft has been POR, primed and top coated, and u joints installed.
I started on the carb and ran into something right away with the Edelbrock intake.
These pics are taken from the pass side.
What is that hole in the top of the intake for? I know I have to remove the bolts and put the block off plate on, but what's the other one?
You can see in the next one that the spacer doesn't cover the hole all the way.
.....and in this one you see the gasket covers the hole, but......it'll still leak air, no?
  #131
Old 02-20-2014, 11:16 PM
Gary Lewis's Avatar
I think you have the EGR version. Here's what Edelbrock says:
PERFORMER 351W EGR (idle-5500 rpm)
Designed for street Ford 351-Windsors with EGR. #3781 is stock replacement/street legal part for 351-W 2V V8s; 1972-87 and works with either the OEM 2V carb or an aftermarket EGR 4V carb for off-road by using Edelbrock #8053 4V EGR plate and compatible EGR valve and gasket.
And it looks like this, with the same hole yours has:
So you need the #8053 4V EGR plate. Or, some way to positively cover that hole.
  #132
FordFETruck's Avatar
FordFETruck FordFETruck is online now
FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.
Looks like you have an EGR intake manifold?
  #133
Old 02-20-2014, 11:31 PM
Yeah I know I have the EGR but really didn't know what that meant at the time. I first ordered the non-EGR and when I sat it on the engine it looked like it didn't fit along the sides of the heads, so I sent it back and ordered the EGR only to find out that it fit the same way. I guess that's how it is supposed to fit and I just stuck with the EGR one. Should I have sent it back and got the non EGR one? If I plug all the holes is the performance the same on these two intakes? Part # 8053 is 70$ both intakes were the same amount of $ I think. I don't think I can return it now
"EGR" means what exactly?
  #134
Old 02-20-2014, 11:40 PM
Exhaust Gas Recalculation.
  #135
Old 02-20-2014, 11:42 PM
Just checked, the EGR was 60$ more to begin with.
Let me tell you a story... FoxFord33 Ranger & B-Series 2 01-22-2017 12:58 AM
F150 Resto (Grandpas 85) Chevra 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 10-24-2016 02:41 AM
Contemplating 1972 F6/700 Dump Purchase 94150 Large Truck 10 02-12-2016 01:18 PM
Newbie rockhardplace011 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 11-03-2015 01:24 PM
Alert Incoming New Guy skyde 1957 - 1960 F100 & Larger F-Series Trucks 12 04-22-2015 08:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
