Newbie 85 f250 frame off resto (Image Heavy) - Page 8 - Ford Truck Enthusiasts Forums
  #106
Old 01-22-2014, 02:40 AM
slashfan7964's Avatar
slashfan7964 slashfan7964 is offline
slashfan7964 is gaining momentum as a positive member of FTE.slashfan7964 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by FordFETruck View Post
Put a Ford engine in a Chevy!
I will never, EVER put a GM engine into any Blue Oval. I am not a traitor.
Quote:
Originally Posted by Brad from Oz View Post
The popular swap over here is the 4.0 litre quad cam Lexus V8 into the early 70's silly-cars. Fairly easy swap, a previous workmate of mine ( he was my apprentice at one point) did it to his along with the 4 speed auto, narrowed a Hilux diff with a Torsen diff centre. What a great package, awesome power to weight and great economy, looks stock.
I've heard of that being done before. I've found a 302 swap online but that engine is too mainstream, for even as good as it is. Couple of others I wanted to try was a 351C Miata, and a flathead 240Z.
That's another thing I like. I like to make the engines "appear" stock. I will go so far as to paint an aftermarket intake and machine the ends of aluminum heads to make them match factory heads and have them painted as well. I kind of got this idea from my dad who leaves the motor stock locking and builds up the inside.
I've always wanted to build a sleeper as well. Like some old rusted out beat up car with a built big block, but with an extremely quiet exhaust with mechanical cut outs to scare people that want to race lol.
I am also a fan of modded old school inline 6's. a friends dad had a 240 I6 Maverick Grabber with a 3 speed manual. He said all he did was put 4.56 gears it and shifted it so fast he spanked a Chevelle SS 396. I wouldn't mind trying a turbo 300 I6 in a 4 door Maverick. I am partial to N/A power, but parts for a 300 aren't exactly cheap and common, so a turbo might be my best option. I've heard of using a turbo from a factory 6.5 V8 GM diesel, and based on induction, either an intake/4 barrel or 302 injectors, paired with a set of headers. Apparently its good for around 250 horse @3,800 and 430 lb-ft @ 1,600. Would make for some fun in a Mav without hurting fuel economy (this combo nets an average of 15mpg) and reliability.
  #107
Old 01-22-2014, 04:57 AM
Brad from Oz's Avatar
Brad from Oz Brad from Oz is offline
Brad from Oz has a good reputation on FTE.Brad from Oz has a good reputation on FTE.Brad from Oz has a good reputation on FTE.
Quote:
Miata is an MX5 right? If so then to fit any other engines (rotary, v6, v8 etc.) you need to do a space frame front end. Bullet cars are the gurus in these, they have done lots of different combos over the years and they stretch the front end along with the space frame. Their current combo is a supercharged Lexus v8.
Bullet Cars - Bullet Roadster SS Roadster Bullet Cars for Sale
240/260z - easy, lots of them with 350chevs in them so a flathead should go easy.
  #108
Old 01-22-2014, 01:28 PM
Yeah I knew you'd have to do something along those lines. Yes the Miata is an MX5. 302s and LS1's are very common swaps.
I've seen a few V8s go in them. The flathead would need a good built though since it would be making less power than stock.
  #109
Old 01-22-2014, 01:36 PM
Luke76's Avatar
Luke76 Luke76 is offline
Luke76 has a good reputation on FTE.Luke76 has a good reputation on FTE.Luke76 has a good reputation on FTE.
Quote:
Originally Posted by Piston Honda View Post
Quote:
Originally Posted by Luke76
You could try a different balancer installer - the one I use has a "plate" or flange that would have covered your recessed hole completely so that both nuts remained outside where you could reach them. It is an OTC 4531.
I know that installer is on Amazon but did you borrow one from an auto part store or did you buy one?
Sorry for the late reply, but yeah, I actually just bought that very one from Amazon. The only tool rental place we have locally is AutoZone and the kit they have for rent is the
Great Neck 27144 Great Neck 27144
. It doesn't seem to be as good and it gets poor reviews, but it might still work. I think I was just in a tool-buying mood. No question the OTC kit makes it very easy.
Sorry to change the topic... carry on everyone.
  #110
Old 01-22-2014, 01:48 PM
Piston Honda's Avatar
Piston Honda Piston Honda is offline
Piston Honda is starting off with a positive reputation.
Quote:
Originally Posted by Luke76 View Post
Sorry for the late reply, but yeah, I actually just bought that very one from Amazon. The only tool rental place we have locally is AutoZone and the kit they have for rent is the Great Neck 27144. It doesn't seem to be as good and it gets poor reviews, but it might still work. I think I was just in a tool-buying mood. No question the OTC kit makes it very easy.
Yeah, the Great Neck one is the one I borrowed from AutoZone.
Thanks
  #111
Old 01-22-2014, 08:33 PM
1985 Bronco's Avatar
1985 Bronco 1985 Bronco is offline
1985 Bronco is starting off with a positive reputation.
I would love to build a maverick! I've promised myself that the next old car I'm going to buy is going to be a maverick. If I sell the Bronco, I'm going to pull the 460 out of it, and drop it in the maverick!
  #112
Old 01-22-2014, 11:08 PM
My friends dad (same guy that had the 240 I6 car) later put a 392 stroker in it as well as in one other, had the fender walls cut out and had them both ridiculously tubbed out, wiiiide tires. Fastest cars in the county for years. Recently sold them last summer, and now they are being professionally raced in Kansas.
I'd like to built the turbo 6 4 door...no one would see that coming at all. Especially in a beater.
  #113
Old 01-27-2014, 03:47 PM
Zeitgeist57 Zeitgeist57 is offline
Zeitgeist57 is starting off with a positive reputation.
Looking great!
  #114
Old 01-30-2014, 02:23 PM
Quote:
Originally Posted by Zeitgeist57 View Post
Looking great!
Thanks!
Ok, so I've ordered a new Ford sending unit , Holley aluminum 4160, and some misc. grade 8 bolts. Once I receive the carb I'll see what I need for fittings for the stainless braided hose from pump to carb.
I'm researching headers right now, and it looks like shorties are the way to go. I want ceramic coated, and there is not many to choose from. I've come up with JBA, Gibson, Flowtech, and Hedman. The Gibson reads "1- Has no air injection 6- will not fit 87-90 models with A.I.R. into each port". The pictures that I've looked at online has some sort of off shoot coming off one of the tubes. The Hedman reads 5- with A.I.R. System. These headers have a small inlet/outlet coming form one of the tubes. I know I don't have this "A.I.R. System", but what are these inlet/outlets, and why are they on both the A.I.R. and non-A.I.R. The JBA and Flowtech have no inlet/outlets.
  #115
Old 02-07-2014, 10:08 AM
Does anyone know anything about these headers?
  #116
Old 02-07-2014, 10:41 AM
f150xltlarait f150xltlarait is offline
f150xltlarait is starting off with a positive reputation.
I have long tubes on my 85 and shorties on my 86 both 351W http://www.summitracing.com/parts/he...50?prefilter=1
for F150 302 but I have on an F150 with a 351w fit just fine
http://www.summitracing.com/parts/he...85/model/f-250
  #117
Old 02-07-2014, 11:31 AM
Are these trucks 4x4?
  #118
Old 02-07-2014, 01:55 PM
yes they are both 4x4
  #119
Old 02-18-2014, 09:40 AM
Thanks for the info, you steered me in the right direction....kinda. I looked at the long tubes in your link and it looks like a lot of the long tubes don't fit a dana 60, which I have, but I did find something. Ended up getting the silver ceramic coated Hooker Competition Headers( long tubes).
I haven't fit them up yet. I'm waiting for my front driveshaft to be ready, I had it shortened by 1" to complete the swap. I went to pick it up yesterday and there was a piece of slag rolling around in there
In the mean while I installed the sending unit and then painted the tank and straps. I'll try and get that in today, and get the brakes buttoned up.......just got a call, the driveshaft is done so I'll get some paint on that.
  #120
Old 02-19-2014, 09:38 PM
Bad news... Headers don't fit, here's a couple pics
I've got about 1 1/4" from the differential to the header. I thought the drive shaft would be the issue but it's the diff.
It's to bad, they look great.
Anybody out there have headers and the dana 60?
Let me tell you a story... FoxFord33 Ranger & B-Series 2 01-22-2017 12:58 AM
'67 F100 daily driver project commencing soon. JTool 1967 - 1972 F-100 & Larger F-Series Trucks 28 03-14-2016 07:06 AM
Contemplating 1972 F6/700 Dump Purchase 94150 Large Truck 10 02-12-2016 01:18 PM
Newbie rockhardplace011 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 11-03-2015 01:24 PM
Alert Incoming New Guy skyde 1957 - 1960 F100 & Larger F-Series Trucks 12 04-22-2015 08:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
