Newbie 85 f250 frame off resto (Image Heavy) - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 10-06-2013, 10:30 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
What I meant was that you should be able to spin the input shaft in neutral without the output shaft turning. Or vice versa. It is possible to get the shifter rails out of sync on the NP435 such that you are in two gears at the same time. If you still have the shift lever out the use a screwdriver or somesuch to move the gears around until you get both sides in neutral. If the lever is in you have to take it out again.
  #62
Old 10-06-2013, 10:40 PM
Piston Honda's Avatar
Piston Honda Piston Honda is offline
Piston Honda is starting off with a positive reputation.
Quote:
Shifters not in so that's good. I'll give it a try tomorrow. Thanks.
  #63
Old 10-06-2013, 10:45 PM
Gary Lewis's Avatar
It is pretty easy to get it in two gears at once with the lever out. Been there, done that - while putting the lever in. Make sure to check before you power up.
  #64
Old 10-07-2013, 01:06 AM
Ken Blythen's Avatar
Ken Blythen Ken Blythen is offline
Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.Ken Blythen has a very good reputation on FTE.
Quote:
Originally Posted by Piston Honda View Post
The input shaft is not spinning but the output shaft is. Any idea on how to correct this?
You might have to remove the lid & start again.
Normally if two gears are engaged at once, everything would be locked up...........I think you might have one selector out of place.
  #65
Old 10-07-2013, 09:20 AM
Sorry, when I said the shifters not in I meant shifter cover. I'm looking inside it now and the gears on the lower shaft don't slide, correct?
I put tape on the only things turning
  #66
Old 10-07-2013, 09:37 AM
Gary Lewis's Avatar
If that is a view from the top, as I think it is, then the lower gears don't slide. (I've not had my tranny that far apart, so don't recognize the view.). I would turn the cover over and play with it to understand how and what moves, and then play with the tranny to move everything into neutral. You will see shifter "forks" that grab the sliders, and those are what you want to move to find a point where nothing is engaged.
  #67
Old 10-07-2013, 02:54 PM
I think I got it. The input shaft turns but not very easy.
  #68
Old 10-07-2013, 02:58 PM
Gary Lewis's Avatar
If the input turns and the output doesn't you are in neutral.
  #69
Old 10-07-2013, 10:43 PM
4x484150's Avatar
4x484150 4x484150 is offline
4x484150 has a good reputation on FTE.4x484150 has a good reputation on FTE.
Hey Piston, where in NH are you?
  #70
Old 10-08-2013, 07:53 AM
Quote:
Rochester
  #71
Old 10-08-2013, 11:10 PM
4x484150's Avatar
Rochester
Why the rolling eyes? Id love to stop by and check out your work first hand
  #72
Old 10-15-2013, 09:43 AM
Haven't posted in a week, I've been extremely busy with other things. But I have worked on the truck/garage. I put the rear wheels on and lowered the front onto wheel dollies with some wood blocking in between. After the chassis was outside I did a deep clean in the garage to setup for spraying. Sorry about the pics, there a little blury.
From garage to paint booth
Two coats of tie coat primer
If you have been to rochester you might know why the roll of the eyes. Don't take this the wrong way but, I'm kinda new to going on forums and don't feel very comfortable giving people I don't really know my address. Maybe I'll attend a NH meeting first to break the ice. Am I a jerk?
Oh yeah, also made a cart to put the cab on. I'll take some pics later.
Should be spraying finish coats on today. I don't know if I should sand the primer before I top coat it. I think it should be fine but the final product might look better if I do sand. If I sand though I'll have to put the rear wheels on again and roll it outside and wash it again and wait for it to dry...........winters coming and I want to start assembling engine and everything, get it running and put in storage for the winter. Any thoughts?
  #73
Old 10-15-2013, 10:08 AM
Gary Lewis's Avatar
Looking good, PH.
I agree, I don't put my address on for everyone.
As for sanding the primer, I don't think it is needed, and the texture gives the finish coat something to hang on to. But that just my thinking, I am no paint nor body man.
  #74
Old 10-15-2013, 11:12 AM
Yeah, I'm probably going to just spray it. I went and got some tractor paint from tractor supply, gloss black. Anyone use this before?
  #75
Old 10-15-2013, 05:29 PM
4x484150's Avatar
No, Ive never been to Rochester itself, only drove through once.
Totally understandable. Maybe Im too niave about meeting people, or too trusting? Ive never had an issue with the wrong sort of folks from the internet.
Im planning on going to the NH get together on sunday.
Let me tell you a story... FoxFord33 Ranger & B-Series 2 01-22-2017 12:58 AM
F150 Resto (Grandpas 85) Chevra 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 10-24-2016 02:41 AM
Contemplating 1972 F6/700 Dump Purchase 94150 Large Truck 10 02-12-2016 01:18 PM
Newbie rockhardplace011 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 11-03-2015 01:24 PM
Alert Incoming New Guy skyde 1957 - 1960 F100 & Larger F-Series Trucks 12 04-22-2015 08:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
