Newbie 85 f250 frame off resto (Image Heavy)
Old 09-28-2013, 11:00 PM
kburton66's Avatar
kburton66
kburton66 is offline
What color are you going to paint your gas tank(s)?
  #47
Old 09-29-2013, 07:16 AM
Piston Honda's Avatar
Piston Honda
Piston Honda is offline
Originally Posted by truckertrav
If I recall, I believe you push down on the ring around the base of the shifter and turn to unlock from the drift pin...
Hopefully, someone will add to or correct me...(I haven't messed with trannys too much....Trav..
Thanks for the reply.
I tried doing this and the ring dosent seem to move down at all. It's tight against the shifter base.
Hi kburton66, I've been thinking about that and don't know what color to paint the tank. Yes, there's only one I'd like to have two and since I need another bed I could find one with two fuel doors. I think the bare metal paint I have would look good with the straps black maybe. But I also don't want it to look to crazy under there with to much of the gray. Once the motor and transmission are in ill see how it looks and decide.
  #48
Old 09-29-2013, 07:29 AM
slashfan7964's Avatar
slashfan7964
slashfan7964 is offline
Definitely subscribing to this. My dad rebuilt his '85 frame up around 1993 and we are planning on doing it again soon since road salt ate it and after parking it for 7 years, the New York weather tools its toll. Still runs great and moves perfectly though. We've been slowing stocking up on parts. Scored an entire southern front clip, every piece down to nut and bolt for $250 about a year and a half ago.
Keep me updated man, it looks awesome. Glad to see someone taking interest in the '80s Fords. My favorite body style truck ever.
  #49
Old 09-29-2013, 07:57 AM
Piston Honda
Welcome! This truck is on my mind ALL the time and can't wait to drive it! Around here there is not to many of the 80-86 fords, everyone is Chevy crazy. So I can't wait to show it off!
  #50
Old 09-29-2013, 08:03 AM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
The thing you have to push down and turn is the piece inside the ring. I had to pad it with a rag, but gloves might work, as it is a hard push and not finger-friendly.
  #51
Old 09-29-2013, 08:08 AM
Piston Honda
Thanks, I'll give it a try.
  #52
Old 09-29-2013, 08:15 AM
itlives's Avatar
itlives
itlives is offline
Great thread! Subbed. I've only done one frame off resto - a 1958 VW beetle.
It was a lot simpler than this. I don't think I'd want to do what you're doing but I can live vicariously through your work!
More pics!
  #53
Old 09-29-2013, 08:29 AM
slashfan7964
Totally feel you there man. I do see a lot of '80s trucks which is nice though but yeah the Chevy craze is insane lol.
  #54
Old 10-04-2013, 08:06 AM
Piston Honda
I haven't tried to take the shifter off of the cover but, I've been replacing all the gaskets on the transmission and getting it painted up along with some other pieces.
Gaskets finished! One more final cleaning.
Taped and prepped
Two coats of POR15
Hubs and spindles cleaned up nice with the wire wheel
Two coats on those as well
Here's some pics of the frame with axles and cross members installed.
I need to figure out how I'm going to locate the holes for the cab mounts. Anyone know what size the holes are on the rear cab crossmember for the mounts?
  #55
Old 10-04-2013, 08:48 AM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Looks good! Excellent job on the tranny.
  #56
Old 10-04-2013, 07:47 PM
Piston Honda
Got it! Thanks guys.
  #57
Old 10-04-2013, 07:59 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
Kinda hurts, doesn't it? Amazing how stiff they made it.
  #58
Old 10-06-2013, 05:27 PM
Piston Honda
OK, I should have checked to make sure the input shaft still turned before I painted the tranny. If it's in neutral the shaft should spin, no? I'm 90% sure it turned before I took it apart.
  #59
Old 10-06-2013, 06:14 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
In neutral the input shaft should spin and the output shaft shouldn't.
  #60
Old 10-06-2013, 07:22 PM
Piston Honda
The input shaft is not spinning but the output shaft is. Any idea on how to correct this?
Quick Reply: Newbie 85 f250 frame off resto (Image Heavy)
