Newbie 85 f250 frame off resto (Image Heavy) - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 09-17-2013, 10:01 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
What paint did you use on the drums? The other parts look like Eastwood's paint.
  #32
Old 09-17-2013, 10:11 PM
Piston Honda's Avatar
Piston Honda Piston Honda is offline
Piston Honda is starting off with a positive reputation.
Quote:
Dupli color ford blue engine paint and cast coat aluminum. I'm painting the calipers blue too.
  #33
Old 09-17-2013, 11:48 PM
4x484150's Avatar
4x484150 4x484150 is offline
4x484150 has a good reputation on FTE.4x484150 has a good reputation on FTE.
Your thread has inspired me to get a garage! Someday. Awesome work, when I do my restoration in however many moons from now, I would like to follow your example.
  #34
Old 09-18-2013, 08:04 AM
Quote:
Thanks! When we were looking at houses seven years ago we pulled in this driveway and I saw the garage I said "this is the one". My wife said" we haven't even went inside" " it doesn't even matter" I told her.
Well I didn't get any thing done on the truck yesterday I'm going to try and make some progress today.
Can anyone recommend a good paint gun? I need to pick one up pronto if I want to keep this project going seeing how the next step is to paint the chassis before I assemble the front end.
Btw thanks to everyone for the compliments!
  #35
Old 09-18-2013, 08:05 PM
Alright guys, I'm really proud of this one. I tried out a welder I got a little while ago and made this piece up.
I also made a dust trap for the blast cabinet. Hopefully it will be a little easier to see while blasting the last of the pieces.
  #36
Old 09-18-2013, 08:17 PM
FordFETruck's Avatar
FordFETruck FordFETruck is offline
FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.
The fabbed up piece looks great!
  #37
Old 09-18-2013, 08:21 PM
str8sixman's Avatar
str8sixman str8sixman is offline
str8sixman is starting off with a positive reputation.
excellent job on the crossmember! i had the exact same peice rusted out on mine when i bought it, i ended up taking the crossmember out and turning it around as the other side was still good. not a proper fix but it will hold till i can get it fixed. let me know if you make more and want to sell one my way!
  #38
Old 09-18-2013, 08:25 PM
Thanks. I'll probably have to do some more metal work to the rear cab crossmember. Either that or get another one some where. Are all years the same?
  #39
Old 09-18-2013, 08:31 PM
Quote:
It took a little while.If I charged by the hour it might be cheaper to buy a new truck.
  #40
Old 09-18-2013, 08:40 PM
str8sixman's Avatar
haha hey thats why we build em....its a great way to spend a little while
  #41
Old 09-18-2013, 09:19 PM
Gary Lewis's Avatar
Good job! On my blast cabinet I use a $20 Craftsman shop vac with a drywall filter in it.
  #42
Old 09-25-2013, 09:39 PM
We'll I had to take a few days off and do some other stuff but the blast cabinet works a lot better with the vac and dust trap set up, peices are all cleaned up. I did some fabrication on the rear cab crossmember, three areas on it were rotted.
I also sand blasted this crossmember again after fab but didn't take any pics, probably should have.
Cross members and shock towers are now painted and awaiting installation. I figure a few days and the paint should be hard enough to assemble.
Ended up ordering some better paint guns. They should be here in 3-4 days and the top coating can begin.
Next step transmission and transfer case!
  #43
Old 09-26-2013, 08:16 PM
86fordtruck's Avatar
86fordtruck 86fordtruck is offline
86fordtruck has a good reputation on FTE.86fordtruck has a good reputation on FTE.86fordtruck has a good reputation on FTE.
Good job, so far. Subscribed.
  #44
Old 09-27-2013, 10:46 PM
I started in on the transmission and transfer case yesterday. Took the transfer case to the local transmission shop to have all the seals replaced and the housing cleaned up.
As you can see almost all the gaskets and seals are leaking.
Don't laugh at me for using the hoist to move the transfer case, I have a bad back right now.
I pulled the counter shaft rear bearing cap off and half the needle bearings fell out so I took the rest of them out and taped up the hole where the bearing race is and blasted it, cleaned it and put all the needle bearings back in with assembly lube.
Shifter cover cleaned up, don't know if I'll polish it up a bit.
Does anyone know how to take the shifter off of the cover? I still don't know.
  #45
Old 09-28-2013, 09:28 AM
truckertrav truckertrav is offline
truckertrav is gaining momentum as a positive member of FTE.truckertrav is gaining momentum as a positive member of FTE.
If I recall, I believe you push down on the ring around the base of the shifter and turn to unlock from the drift pin...
Hopefully, someone will add to or correct me...(I haven't messed with trannys too much....Trav..
Let me tell you a story... FoxFord33 Ranger & B-Series 2 01-22-2017 12:58 AM
'67 F100 daily driver project commencing soon. JTool 1967 - 1972 F-100 & Larger F-Series Trucks 28 03-14-2016 07:06 AM
Contemplating 1972 F6/700 Dump Purchase 94150 Large Truck 10 02-12-2016 01:18 PM
Newbie rockhardplace011 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 11-03-2015 01:24 PM
Alert Incoming New Guy skyde 1957 - 1960 F100 & Larger F-Series Trucks 12 04-22-2015 08:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
