Newbie 85 f250 frame off resto (Image Heavy) - Page 21 - Ford Truck Enthusiasts Forums
  #301
Old 04-02-2014, 09:47 PM
Piston Honda's Avatar
Piston Honda Piston Honda is offline
Piston Honda is starting off with a positive reputation.
Quote:
Originally Posted by ArdWrknTrk View Post
The timing marks on the damper are directly linked to the piston.
They will always line up.
Check that you have good grounds.
I know you just painted everything.
When I bring the #1 piston to TDC the timing mark doesn't line up with the timing cover, it's pointing straight down
The paint has been removed from the ground spots and I put dielectric grease on the frame under the connections to try and keep the rust and corrosion away.
  #302
Old 04-02-2014, 09:50 PM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
I'm not sure how that could happen....
  #303
Old 04-02-2014, 09:54 PM
Just to make sure, if your looking at the front of the engine the #1 cylinder is the pass side front, correct?
  #304
Old 04-02-2014, 09:55 PM
pedant
Swap the red and white wires.
Just jumper the solenoid by touching a bare wire from the battery+ post to the 'S' terminal.
  #305
Old 04-02-2014, 09:58 PM
pedant
Quote:
Yes, #1 is front passenger side.
That bank is 1234 going towards the firewall.
The drivers side is 5678 from front to the firewall.
  #306
I tried doing that earlier, nothing.
  #307
Old 04-02-2014, 10:11 PM
The crank gear of the timing set has three keyways, stock, advance, and retard. Even though I'm 100% sure I lined up the stock keyway to the cam gear, if the crank gear was put on using one of the other keyways would that cause those marks not to line up?
  #308
Old 04-02-2014, 10:14 PM
pedant
The damper is keyed to the crankshaft not the camshaft...
Stock is retarded, for emissions.
You probably want centered.
  #309
Old 04-02-2014, 10:20 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
But none of that has anything to do with the pointer's orientation on the harmonic balancer.
  #310
Old 04-02-2014, 10:21 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is offline
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
The only way I can see the mark on the damper pointing down is if you have a bad damper or the wrong damper. Oh, or put it on w/o the key.
  #311
Old 04-02-2014, 10:44 PM
Sorry, I meant standard, not stock.
Quote:
I didn't think so, but my father in law mentioned it, but he wasn't sure either.
Quote:
I checked the part# of the damper when I had the pulley alignment issue! and it's the correct#. The key is in there.
  #312
Old 04-02-2014, 10:48 PM
Gary Lewis's Avatar
Chris is right - lets get the TDC thing figured out, and it doesn't involve the cam. Is the damper new?
  #313
Old 04-02-2014, 10:59 PM
pedant
Straight up timing is the way to go.
You have that right.
I don't know what's up with your timing marks unless the damper has slipped.
Just bring #1 to TDC compression and stab the distributor in so the rotor is pointing at the #1 terminal.
Rotate it a little bit clockwise and fire it up.
  #314
Old 04-02-2014, 11:29 PM
The damper slipping sounds possible now that you mention it, it is two piece, right? If the damper has slipped would that have effected the way it ran before I tore the motor down?
I just went out and took a pic of the damper
After looking at the Haynes book, I think the timing mark I see on the bottom is used on a six cylinder.
I started looking for the timing marks for a V8
I stuck a mirror on top of the damper and the marks are on top
Am I missing a pointer that attaches to the timing cover?
  #315
Old 04-02-2014, 11:35 PM
Gary Lewis's Avatar
Yes, you are missing the pointer.
F150 Resto (Grandpas 85) Chevra 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 10-24-2016 02:41 AM
Contemplating 1972 F6/700 Dump Purchase 94150 Large Truck 10 02-12-2016 01:18 PM
Newbie rockhardplace011 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 11-03-2015 01:24 PM
Alert Incoming New Guy skyde 1957 - 1960 F100 & Larger F-Series Trucks 12 04-22-2015 08:47 AM
2002 Econoline work van, 5.4L, no power after long set up RandyJ2007 Modular V8 (4.6L, 5.4L) 6 01-02-2012 09:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
