Newbie 85 f250 frame off resto (Image Heavy) - Page 2 - Ford Truck Enthusiasts Forums
Old 09-16-2013, 07:42 PM
1985 6.9 IDI's Avatar
1985 6.9 IDI 1985 6.9 IDI is offline
1985 6.9 IDI is starting off with a positive reputation.
Lookin good man, what's the plan for the suspension are you lifting it or stock height? Also what tires are you planning on running?
Old 09-16-2013, 08:19 PM
Piston Honda's Avatar
Piston Honda Piston Honda is offline
Piston Honda is starting off with a positive reputation.
I bought some new leaf springs (stock)and for tires I don't know what's the biggest I could fit without causing any problems. But would like some good size ones. Any recommendations?
Old 09-16-2013, 08:20 PM
FordFETruck's Avatar
FordFETruck FordFETruck is offline
FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.
Subscribed.
Old 09-16-2013, 10:11 PM
My 85 has re-arched springs with 1 extra leaf all the way around and I'm on my second set of 285/75/r16 mud terrains now. Clears fine even before the SAS so I know you will be able to fit 265s and I think you'll be fine with 285s. I had BFG KM2s first, wore decent but the junk ttb front end wasted them too early to save them. I now have Hercules Trail Digger M/Ts and I really like them.
Old 09-16-2013, 10:43 PM
How many leafs 3/1/1rear 2/1 front?
Old 09-16-2013, 10:51 PM
Quote:
I am not by my truck right now to confirm it, but I believe there are 3 leafs on the front and seven or so in the rear. They just added 1 to every spring so whatever stock was +1.
Old 09-17-2013, 09:08 AM
Quote:
Mine only has 3 with one helper in the rear and 2 in the front. Is it a rougher ride with less leafs.
Some more pics
my daughter walked in and said it looked like Christmas with all the stuff hanging, I agreed.
Pulled the carrier out and replaced axle seals in the D60
Positioning axle for install. I lost some time during reassemble do to getting the wrong bolts twice from the company I ordered the leafs from.
New shoes,wheel cylinders, springs and the whole 9. Plus some dog hair on the studs!
Old 09-17-2013, 10:47 AM
SVTDriver97's Avatar
SVTDriver97 SVTDriver97 is offline
SVTDriver97 is gaining momentum as a positive member of FTE.
Subscribed
Deffinetly subscribed to this!
I'm in the process of doing the same thing to my truck.
Old 09-17-2013, 01:38 PM
I would think less leafs would make it ride better, mine rides like a brick haha. Also mine is a 250 HD so I think the springs might be different. I reused my f250 springs on the front and was told that they are different than the f350 springs later on, which would explain why it rides so rough. The axles are lookin good dude!
Old 09-17-2013, 02:08 PM
f100beatertruck's Avatar
f100beatertruck f100beatertruck is offline
f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.f100beatertruck has a very good reputation on FTE.
Generally more thinner leaves will be smoother than less thicker leaves given the same weight rating. The more leaves the more progressive it will be but it will also travel farther to carry the same load. There's no free lunch.
Great work btw. Any plans to swap the c-clip rear for a full floater?
Old 09-17-2013, 02:10 PM
Welcome aboard!
Where are you at with yours?
Thanks!
When I was looking at the springs on SD truck springs I searched for 85 f250 and 89 f350 there was quite a few different options but I think they all fit. Just different load ratings.
The diff covers were painted with por Metal Mask. I really like the color! But the pitting in the cover looks kind of crappy up close. I think I'll high build over that, sand, and paint it again.
I did some painting with the metal mask yesterday with a cheap HPLV gun that I just got. Things junk! I'll have to take it back, there's no way ill be able to paint the body with it.
Old 09-17-2013, 02:18 PM
When I went and got the front end the guy had the full floater there but I didn't have the cash I'd like to get one and put a locker in it but it might have to wait till later. Originally I never planed on changing the front end but the more I learned on this and other sites the more I wanted to change it. Who wants to be changing ball joints and tires all the time? I did invest in the whole axle rebuild kit for the D60 so it should last a very long time.
  #28
Old 09-17-2013, 08:12 PM
The TTB axle isn't a bad axle per say but everything is worn out on them at this age. Replace all the bushings, particularly the pivot bushing and they do pretty well. With that said I'm going with the D60 on my SuperCab just because that's what I want.
  #29
Old 09-17-2013, 08:38 PM
SEH43's Avatar
SEH43 SEH43 is offline
SEH43 is starting off with a positive reputation.
For a first timer, you do good worl. Looks nice!
  #30
Old 09-17-2013, 09:50 PM
Isn't the ttb a b$@%# to align properly? No locker available for ttb also, right?
Quote:
Thank you! This is my first pickup I've owned too. Had a 88 bronco and 81 jeep cj7 but never a pickup.
Check out the drums!
F150 Resto (Grandpas 85) Chevra 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 10-24-2016 02:41 AM
Contemplating 1972 F6/700 Dump Purchase 94150 Large Truck 10 02-12-2016 01:18 PM
Newbie rockhardplace011 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 11-03-2015 01:24 PM
Alert Incoming New Guy skyde 1957 - 1960 F100 & Larger F-Series Trucks 12 04-22-2015 08:47 AM
2002 Econoline work van, 5.4L, no power after long set up RandyJ2007 Modular V8 (4.6L, 5.4L) 6 01-02-2012 09:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
