Newbie 85 f250 frame off resto (Image Heavy) - Page 19 - Ford Truck Enthusiasts Forums
  #271
Old 03-05-2014, 11:03 PM
FordFETruck's Avatar
FordFETruck FordFETruck is offline
FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.
Quote:
Originally Posted by ArdWrknTrk View Post
I bought a horseshoe from Dorman for ~$5
Replaced it last year when one of the wires went bare.
(but the plastic connector didn't fail)
Wires were fine, plastic connector was gone. Terminals were a pain to deal with. I didn't know you could buy the plastic piece at the time.
  #272
callen427's Avatar
callen427 callen427 is offline
callen427 is starting off with a positive reputation.
Are those parts I gave a picture of called kick panels? When I ask people if the have the kick panels they give me a picture of the map pocket panel that goes on the door.
  #273
Old 03-05-2014, 11:12 PM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Quote:
http://www.summitracing.com/parts/rn...FSwdOgodCj4A8Q
  #274
Old 03-05-2014, 11:54 PM
Piston Honda's Avatar
Piston Honda Piston Honda is offline
Piston Honda is starting off with a positive reputation.
Ill probably go with the NAPA or Ford. Now that I'm not going with the dodge module, I can use the painless harness.
ArdWrknTrk, you mentioned something about having to cut into the harness. I've searched and didn't find anything. I did notice that the ford harness has two plugs that go into the module, one plug with two wires and one plug with four wires
The painless has both plugs but one has a three way port on it: brown wire to coil, white wire to solenoid, red wire to ballast resistor input.
The funky thing is there is actually four wires coming from this plug and the fourth wire doesn't go to anything. It's right where the wires merge and it doesn't show it on the diagram.
Also, the Painless diagram shows solenoid with two posts "S" and "I", instructions say if you have single post, as I do, then hook it up to that post.
I'm real bad with electrical diagrams so bare with me
Edit: here's a pic of the whole harness
  #275
Old 03-06-2014, 12:38 AM
Seeing this, I searched around and found all the connectors but the distributor connector. If I can find that one I'll just make a harness.
  #276
Old 03-06-2014, 06:23 AM
pedant
I've discussed this before.
You don't need the wire going to the 'I' terminal of your starter solenoid.
That is for retrofitting older points ignition vehicles.
The harness inside your cab already has the retard function and ballast resistor built in.
Be aware that the red/white colors swap at that plug if you had a TFI vehicle.
When you connect it to a blue grommet DurasparkII module you should see red connected to white and white to red.
... the fourth wire is there just because the pigtail comes that way.
They should have pulled those pins, but they don't.
No one makes that distributor connector. (it's not even in the Motorcraft pigtail catalog)
It is the same as the red & white connector, except that the locking nubs are 'clocked' in a different location.
Just file the nubs down and run a tiny TyWrap between the wires and around the plug to make sure it doesn't come apart.
This may seem 'hack', but to me it's not worth $100 more than these three plugs and horseshoe connector cost.
All of these connectors are available from NAPA in their Echlin line, so if you are going to get the TP-40 module, you can get everything there in one shot.
I'll have to see if I can find the thread where I listed those parts numbers.
Maybe Matthew knows, I remember him commenting on it.
  #277
Old 03-06-2014, 07:39 AM
Thanks for the information. Sorry if I'm repeating things that were brought up in other discussions, is there any way to bookmark threads or notes on the site itself? Sometimes it's hard to find things that I have read before.
I've got all the part numbers, thanks again
  #278
Old 03-06-2014, 08:06 AM
pedant
No need to apologize.
These things come up all the time and there is really no way to bookmark or 'favorite' threads here on the site that I know of.
I know KsCop put up a DSII conversion thread that has been stickied.
But he does not have have all the different manufacturers and their parts numbers listed.
When someone has a question about their 2G alternator plug melting down I usually reply with eight different sources.
I haven't done that legwork on these DSII harness connectors.
NAPA numbers are EC72, EC127 and EC238
  #279
Old 03-06-2014, 08:42 AM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is offline
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
I haven't found a way to bookmark on the site. So I use Evernote and keep a list with hot links.
  #280
Old 03-06-2014, 09:00 AM
pedant
Maybe I should reply to the stickied thread with the NAPA part #'s?
  #281
Old 03-06-2014, 09:57 AM
I called DUI about the module and I asked what's the difference from the SMP module and theirs. He said that they are the same case but they increase the dwell to provide the coil with additional saturation time that provides longer spark and more low end power. Do you think this makes a noticeable difference or is this just a marketing gimmick?
I bought the coil and module "kit" for 200$, the module itself is 133$ so the coil cost 67$. It seems like quality coils go for 40$. What's the deal? Is DUI just way over priced?
  #282
Old 03-06-2014, 10:07 AM
Quote:
What's Evernote?
Ignition Coil Connector
Part Number: ECH EC238
Product Line: Echlin Ignition
IMPORTANT INFO: Female Type;w/ 2 Terminals;Black
Ignition Control Module Connector
Part Number: ECH EC127
IMPORTANT INFO: Female Type;w/ 4 Terminals;Black
Part Number: ECH EC72
IMPORTANT INFO: Female Type;w/ 3 Terminals;Black
They're a little expensive through NAPA 20$ for each module connector. The coil connector is reasonably priced at 7$
Here is a site where they're cheaper, but the ignition coil connector comes in a ten pack. The other connectors are sold in singles. 7-8$
Ford Clips And Fasteners
  #283
Old 03-06-2014, 10:22 AM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
What's Evernote?
Let me google that for you
  #284
Old 03-06-2014, 10:38 AM
pedant
If the SMP module needed more dwell why would they also need a resistor to limit charging voltage when run below 10,000 rpm's?
It's bull****.
Saturation is saturation.
If you don't use the resistor, the coil will overheat and fail, because there's already too much dwell.
If you read the article I linked you'll see he says the same thing about the cheaper SMP box from NAPA.
The one I linked from Ebay is SMP's 'premium' Blue Streak line.
Same application, same manufacturer.
How do they "modify" a solid state circuit???
They don't do anything inside, they put a couple of stickers on the SMP box and sell it under their name.
... because everyone knows, racing stickers add horsepower!!!!
(I will probably be sued for this, but I am willing to call out thieves when they are ripping people off)
What about that $17 coil with a +$50 sticker on it???
  #285
Old 03-06-2014, 10:51 AM
Quote:
Originally Posted by ctubutis View Post
"Let me google that for you", that's pretty cool All this is new to me (being my own mechanic, forums and computers in general) thanks again everyone
All the connectors are on their way and the Napa TP40 module will be ready for pickup this afternoon.
It's bull****.
(I will probably be sued for this, but I am willing to call out bull****ers when they are ripping people off)
In the words of Peter Griffin "you know what really grinds my gears"? This guy just straight up lied through his teeth. Oh well, word of mouth is the best form of advertisement.
F150 Resto (Grandpas 85) Chevra 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 10-24-2016 02:41 AM
Contemplating 1972 F6/700 Dump Purchase 94150 Large Truck 10 02-12-2016 01:18 PM
Newbie rockhardplace011 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 11-03-2015 01:24 PM
Alert Incoming New Guy skyde 1957 - 1960 F100 & Larger F-Series Trucks 12 04-22-2015 08:47 AM
2002 Econoline work van, 5.4L, no power after long set up RandyJ2007 Modular V8 (4.6L, 5.4L) 6 01-02-2012 09:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
