Newbie 85 f250 frame off resto (Image Heavy) - Page 17 - Ford Truck Enthusiasts Forums
  #241
Old 03-05-2014, 05:15 PM
Piston Honda's Avatar
Piston Honda Piston Honda is offline
Piston Honda is starting off with a positive reputation.
Quote:
Originally Posted by ArdWrknTrk View Post
Chain saw grindstones are about $3 vs $30 for a brittle carbide burr.
Good looking out! I have been wanting to get a Dremel for a while and picked one up with a coupe of the chainsaw grindstones. Worked great. So I just have to blast and paint the pulley now.
As for the header gaskets I'm just going to use the Flowtech ones. Remflex has a lot of options for the 351w, square port, oval port, along with different size ports and everything, but it doesn't look like they have oval ones to fit my headers.
I'm now trying to figure my Duraspark II system out. The Painless harness is going back. With me getting the Performance Distributors Dyna Module it's pointless to use the Painless harness, I'm basically paying 135$ for a connector or two.
The Dyna Mod has four wires, two to the dizzy and two to the coil. So it does not have the white wire (starter retard feature). Will I run into any problems?
  #242
Old 03-05-2014, 05:24 PM
Quote:
Originally Posted by callen427 View Post
I was wondering id you have had any luck finding interior panels? I cant find an actual dash. I am not a fan of the dash cover pads. Also I can not find the kick panels anywhere!! My truck is missing them and I have had junk yards or the web.
I have all of my panels. My front pillar pieces are cracked at the screw holes. I might try and epoxy them and then cover them in blue vinyl, though it would be nice to get some good used ones, but it is very hard to find ANYTHING for these trucks around here. Junkyards around here rarely have vehicles older than 94.
  #243
Old 03-05-2014, 05:38 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
I've done a LOT of research on this and have talked to several of the vendors directly. For a replacement dash pad you have three choices:
  • Dashes Direct: they make a brand new dash pad using the original tooling that some vendor used to make the original pads. They are available from DD directly, or from others like LMC, but the best price is from Jeff's Bronco Graveyard for $335. One on here just bought one and seems pleased, so that's what I'm going to do.
  • Just Dashes: They take your original pad and put new foam and vinyl on it. We never actually discussed all of the pricing, but the cost of their service is ~$1000 plus shipping of your pad to them.
  • Used: There are several sources of used pads, but what all of them have in common is that the pads are old and, therefore, subject to cracking just like ours did. In fact, some of of have purchased these and they've cracked soon after getting them home. So, I would not pay much at all for one. I saw one recently on eBay that was up to about $100 with 4 days left on the bidding and $50 for shipping. So it could easily have gone for more than half of a new one and might be cracked by the time you get it. Not something I'm interested in gambling on.
  #244
Old 03-05-2014, 05:39 PM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Quote:
Sorry, I don't know anything about the Dyna Mod.
I guess that depends on your compression, initial timing and how hot the engine is.
You may find you have to go to a high torque PMGR starter.
  #245
Old 03-05-2014, 05:56 PM
I hope not, I already bought a new starter before I tore the truck apart.
  #246
Old 03-05-2014, 06:28 PM
I'm going to store the truck in a POD in my yard while I work on the body and I want to hear this thing start and run before I do so. I was planning on fastening the module, ballast resistor and solenoid to a piece of plywood off to the side and hooking up everything temporarily. I have to set up a few more things
Radiator
Dizzy
Module
Resistor
Coil
3G Alternator
Megafuse and holder
Solenoid
Battery and cables
Anything else come to mind?
  #247
Old 03-05-2014, 06:37 PM
pedant
That Dodge ignition module needs a separate ballast resistor?
I'm surprised you didn't go for the 'all in one' solution.
  #248
Old 03-05-2014, 06:47 PM
Dodge?
I think they only offer the one kind of duraspark module.
Edit: in the installation instructions it says to use the resistor on street/strip application 6500 RPM and don't use the resistor on racing applications 10,000+ RPM
  #249
Old 03-05-2014, 06:55 PM
pedant
That's not a "dura spark" module.
It is a Standard Motor Products LX-101 with a couple of stickers on it.
Dodge/Chrysler 1974-83
They say not to use the resistor above 10,000 rpm because at that speed there is not enough time to need reduced dwell or limit the charging voltage with a resistor.
  #250
Old 03-05-2014, 07:01 PM
This is incredible, I have no idea what I'm doing. I thought this was just their brand Duraspark module.
  #251
Old 03-05-2014, 07:04 PM
pedant
I'm sure they will sell you whatever you want to believe.
It can be used, but I doubt it's any better than stock DSII.
Dirt Cheap Electronic Ignition
  #252
Old 03-05-2014, 07:23 PM
At 140$ I think I'll send it back, I'm going to go broke because of return shipping on this project.
  #253
Old 03-05-2014, 07:34 PM
pedant
OMG !$!$!
I know that Performance Distributors is a site sponsor, but that doesn't mean they aren't selling snake oil.
I guess that's how they can afford flashy banner ads???
I once bought a $40 Ebay HEI just to show my buddy Joey what he was paying for with his DUI distributor...
Exact same.... except the stickers.
Right down to the machining marks, and we measured it ALL with a micrometer.
  #254
Old 03-05-2014, 08:19 PM
Gary Lewis's Avatar
And, the machining marks may have originally been a mistake. My nephew sent some prototypes offshore for replication and they did - down to the machining marks and, in some cases, errors. They were so "accurate" they couldn't tell the originals from the copies.
  #255
Old 03-05-2014, 08:29 PM
pedant
I don't know about that, but you could tell that they were made on the same tooling.
F150 Resto (Grandpas 85) Chevra 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 10-24-2016 02:41 AM
Contemplating 1972 F6/700 Dump Purchase 94150 Large Truck 10 02-12-2016 01:18 PM
Newbie rockhardplace011 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 11-03-2015 01:24 PM
Alert Incoming New Guy skyde 1957 - 1960 F100 & Larger F-Series Trucks 12 04-22-2015 08:47 AM
2002 Econoline work van, 5.4L, no power after long set up RandyJ2007 Modular V8 (4.6L, 5.4L) 6 01-02-2012 09:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
