Newbie 85 f250 frame off resto (Image Heavy) - Page 15 - Ford Truck Enthusiasts Forums
  #211
Old 03-04-2014, 08:30 PM
Piston Honda's Avatar
Piston Honda Piston Honda is offline
Piston Honda is starting off with a positive reputation.
Got a few things done today. I brought the balancer down to the local machine shop and got it sleeved, forgot to take a pic but it's done, 12$. The new non-EGR intake is installed along with the carb and fuel hoses. I just mocked up the hose from the pump to carb but will eventually use SS braided hose I think.
I'm going to order locking header bolts as well as locking collector bolts tonight.
The headers come with gaskets, but was thinking about getting some better quality ones. Has anyone used Remflex gaskets before?
  #212
Old 03-04-2014, 08:34 PM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Did you ever get the pulley off your alternator?
  #213
Old 03-04-2014, 08:35 PM
FordFETruck's Avatar
FordFETruck FordFETruck is offline
FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.
That engine looks great, what kind of paint is on the valve covers? or is it powder coated clear?
  #214
Old 03-04-2014, 08:41 PM
Quote:
No, I need some kind of carbide bit or something to remove some of the mushroom.
  #215
Old 03-04-2014, 08:48 PM
Quote:
Thanks, you can't see it from this pic, but there's a big run in one of the covers. I painted them when it was still summer and it was getting dark out, so that's my excuse. I used Duplicolor cast aluminum and then Duplicolor clear engine enamel.
  #216
Old 03-04-2014, 08:49 PM
pedant
Carbide burrs are expensive and brittle.
Maybe a chainsaw sharpening grindstone would fit right down in there?
  #217
Old 03-04-2014, 08:51 PM
pedant
It really does look great!
Where did you get your stainless bolt kit ?
  #218
Old 03-04-2014, 08:56 PM
Looks like an ARP dress kit.
Here's my engine.
My engine is sporting Duplicolor engine enamel too!
Except I did a crappy prep job on the front of the heads, I'll fix that this summer.
  #219
Is there a chainsaw sharpening grindstone that goes in a drill or a die grinder?
  #220
Old 03-04-2014, 09:03 PM
pedant
I have ones that fit my Roto-Zip and Dremel tools.
Do you have an 1/8" collet for your die grinder?
They usually have reducers in the Roto-Zip displays.
  #221
Old 03-04-2014, 09:11 PM
Here's my engine.
Looks good, how did you set up your alternator without using the smog pump bracket? It looks like you don't have any bracket there.
Yeah, it's an ARP bolt kit. I had issues with the kit, there were multiple bolts missing or the wrong length. At first the gentleman on the phone at ARP didn't seem to friendly, but they did end up sending the correct and missing bolts.
  #222
Old 03-04-2014, 09:13 PM
I'll have to check out the reducers tomorrow.
  #223
Old 03-04-2014, 09:17 PM
pedant
Quote:
Chain saw grindstones are about $3 vs $30 for a brittle carbide burr.
  #224
Old 03-04-2014, 09:19 PM
Here's my engine.
Also, I see that you used the stock oil cap that runs back to the air cleaner. If you notice I am using a different type of oil cap. What's the difference between the two caps? Is there a benefit to the hose running to the cleaner?
  #225
Old 03-04-2014, 09:29 PM
pedant
You're sucking clean filtered air into your engine???
As for an alternator bracket, you can find them at JBG or cheap on Ebay.
F150 Resto (Grandpas 85) Chevra 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 10-24-2016 02:41 AM
Contemplating 1972 F6/700 Dump Purchase 94150 Large Truck 10 02-12-2016 01:18 PM
Newbie rockhardplace011 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 11-03-2015 01:24 PM
Alert Incoming New Guy skyde 1957 - 1960 F100 & Larger F-Series Trucks 12 04-22-2015 08:47 AM
2002 Econoline work van, 5.4L, no power after long set up RandyJ2007 Modular V8 (4.6L, 5.4L) 6 01-02-2012 09:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
