Newbie 85 f250 frame off resto (Image Heavy) - Page 14 - Ford Truck Enthusiasts Forums
  #196
Old 02-24-2014, 11:46 PM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Ouch, you bought the Painless harness.
You are going to have to cut into that and separate a couple of wires for the timing retard to function properly.
Do a web search i think you'll find out what I'm talking about.
Good luck.
  #197
Old 02-25-2014, 12:08 AM
Piston Honda's Avatar
Piston Honda Piston Honda is offline
Piston Honda is starting off with a positive reputation.
Is the painless harness any good? I thought it wouldn't require any modification to work. I searched for the timing retard issue but found nothing.
  #198
Old 02-25-2014, 03:34 AM
FordFETruck's Avatar
FordFETruck FordFETruck is offline
FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.
Those headers look great, looks like you can get a socket wrench on most of the bolts, too. I did all of mine by hand with the 6912 HKR's I have. I even used an milodon header bolt kit with a one size smaller head than the supplied bolts. Had to use two supplied bolts, the milodon bolts were longer than supplied and wouldn't make it past a bend on each header. Next time I will use bolts with alan heads in the middle!
  #199
Old 02-25-2014, 07:03 AM
pedant
Quote:
I'm sure the Painless harness is just fine in most regards.
Not trying to knock it.
Their harness may have changed in the years since I tried to set one of these up in John's red Pantera.
IIRC, there was a splice in the Painless 'retard' wire that basically kept the timing retard hot at all times.
  #200
Old 02-25-2014, 12:12 PM
ArdWrknTrk, what pulley did you use for your 3G upgrade?
  #201
Old 02-25-2014, 12:13 PM
pedant
I used the one that was already on my 2G alternator.
  #202
Old 02-25-2014, 12:18 PM
You didn't have a double groove pulley?
  #203
Old 02-25-2014, 12:24 PM
pedant
Yes, I do.
The A.I.R. pumps are driven off the alternator.
  #204
Old 02-25-2014, 12:51 PM
I'm going to try getting my old pulley off. Have you had any problems with the belt squealing or is everything good, because I've heard of some people having that issue switching from a serpentine pulley to a v belt pulley.
  #205
Old 02-25-2014, 01:32 PM
pedant
Just use an impact gun.
When I first installed it I would get a little screech at startup.
Maybe that was just the new belt stretching?
Bead blasted the pulley and installed a LRC regulator.
Everyone says that a single V belt is only good for 90-100A
I don't think I have any reason to exceed that.
Even jumpstarting numerous cars this winter I haven't had it slip.
Mostly I'm happy because the 3G can put out as much at idle as the 2G could at redline.
  #206
Old 02-25-2014, 01:39 PM
I used an impact to get the nut off, but then impatient me, I hit the shaft with a hammer because the pulley was stuck on there and now the shaft is mushroomed. I should have used a puller or at least used a punch as to not damage the shaft.
  #207
Old 02-25-2014, 01:51 PM
pedant
Don't use a puller if you risk distorting the pulley.
Mine came off pretty easily.
Is there corrosion on the shaft?
  #208
Old 02-25-2014, 02:34 PM
Mine.......not so easy. There is corrosion on the threads but not where the pulley was seated. It's not mushroomed real bad, but enough to keep the pulley from coming off. Maybe I'll try running a die over the shaft.
Hey, it's a little off topic but I've been meaning to tell you thats a nice looking pup. Check out my co pilot, he's my avatar now. I had been trying to figure out how to put a pic there, after I chose the pic a window would come up reading "file failed to upload" and now it's there, weird.
  #209
Old 02-25-2014, 02:58 PM
pedant
Try some PB Blaster and hitting the pulley with a torch.
It should expand enough to break free.
He certainly looks 'cool'!
  #210
Old 02-25-2014, 10:51 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
Cool pup. The other pics were too large. FTE only takes up to a certain size and then "fails to load" them.
F150 Resto (Grandpas 85) Chevra 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 10-24-2016 02:41 AM
Contemplating 1972 F6/700 Dump Purchase 94150 Large Truck 10 02-12-2016 01:18 PM
Newbie rockhardplace011 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 11-03-2015 01:24 PM
Alert Incoming New Guy skyde 1957 - 1960 F100 & Larger F-Series Trucks 12 04-22-2015 08:47 AM
2002 Econoline work van, 5.4L, no power after long set up RandyJ2007 Modular V8 (4.6L, 5.4L) 6 01-02-2012 09:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
