Newbie 85 f250 frame off resto (Image Heavy) - Page 12 - Ford Truck Enthusiasts Forums
  #166
Old 02-22-2014, 12:56 AM
FordFETruck's Avatar
FordFETruck FordFETruck is offline
FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.
Sounds like your water pump, timing cover and balancer all came from the off world. My timing cover, and water pump both have a paper gasket and everything on mine lines up perfectly. What brand is the water pump?
  #167
Old 02-22-2014, 01:01 AM
Piston Honda's Avatar
Piston Honda Piston Honda is offline
Piston Honda is starting off with a positive reputation.
Water pumps a Bosch. I just a couple motor head buddies over here looking at it and they're scratching their heads too.
  #168
Old 02-22-2014, 01:08 AM
Do you have an old water pump for that engine? if so. Measure the shaft distance from the front of the shaft to the front side of the mounting boss for the fan on the pump. That may not be back far enough, causing the pulley misalignment.
  #169
Old 02-22-2014, 01:13 AM
I checked that, it's the same. I'm gonna sleep on it.
  #170
Old 02-22-2014, 07:10 AM
ArdWrknTrk ArdWrknTrk is offline
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
You need either a new balancer or a Speedi Sleeve repair kit to give the new seal a smooth surface to ride on.
Hopefully the FMS hasn't been nicked already.
  #171
Old 02-22-2014, 09:23 AM
Quote:
Originally Posted by Piston Honda View Post
2. Water pump has been changed, but the measurement from the back to the front of each pump is within 1/32 of an inch.
3. When I took the water pump off the timing cover originally I don't know if there was a paper gasket( 1/16" maybe) between them. I know for a fact there was no paper gasket in between the timing cover and the block( another 1/16").
So with the two gaskets and the discrepancy of the 1/32" between the old water pump and the new you get maybe a 1/8"+ of stuff holding the water pump out further.
Are we confused yet?
I think I'm just confused! The water pump isn't out to far the HB is. Late night last night!
  #172
Old 02-22-2014, 11:37 AM
What if I brought the balancer to the machine shop and have 1/8"+ removed from it? That's obviously a last resort thing, but the seal will sit on a different part of the HB and shouldn't leak. I'll set up the power steering pump and see where the pulley is in relation to the crank pulley. I tried doing the same thing with the old alternator but it's hard to tell where it lines up. I had trouble trying to take the pulley off the alt and mushroomed the shaft and can't get the nut back on to tighten the pulley.
  #173
Old 02-23-2014, 09:01 AM
cbrown9064 cbrown9064 is offline
cbrown9064 is gaining momentum as a positive member of FTE.
I found a spacer to use with the installation tool and I'm trying to get the harmonic balancer on I think it's all the way on but the pulleys don't seem to line up correctly.
I measured the depth of the stub on the back of the balancer and I don't think it can go in any more. Why don't the pulleys line up? Am I missing something?
On that top photo it dos not seem like it is on all the way. I would try taking the key out, polish lightly with some emery, clean, oil and put on using the bolt/washer. It should slide on farther...
  #174
Old 02-23-2014, 10:13 AM
I set up the power steering pump temporarily to check the pulleys out and the water pump pulley lines up with the PS pulley.
Your right, it doesn't seem like its on all the way, but it will not go on any further. It doesn't have enough depth for the balancer to go in. The balancer is 2 1/8". The hole around the crank snout is 2" deep. It can not possibly go in any more.
I'm willing to bet anything that the timing gear on the Edelbrock set is thicker. Now, the evidence of where the seal was riding says its in the same spot it was pre build. The FMS was replaced also, so maybe the gear is keeping the HB out and the aftermarket seal has a different reveal than the stock one, coincidentally making the seal fall on the same spot.
I'm going to make a trip to the parts store and see if they have a stock replacement timing set and an Edelbrock one and compare the two.
If someone has a Ford timing set lying around could you throw a measuring tape on it and let me know the thickness?
  #175
Old 02-23-2014, 10:30 AM
pedant
What makes you think the balancer has to be flush with the tip of the crank?
The bolt and washer pull it on until it bottoms.
You've already said that the scoring on the balancer is lined up with the lip of the seal.
If there's a problem it's not with the timing set and it was there before you started this project.
Is the slinger properly in place?
  #176
Old 02-23-2014, 11:47 AM
Originally I thought that they shouldn't be flush, because if they were then the washer would bottom out on both the crank and balancer and there wouldn't be as much pressure holding the balancer on. Someone else posted that they should be flush, so I kinda went with that. Does that make sense?
I don't think there was any issue to begin with. If there was an issue, you would think the belts would squeal and such, but they didn't and the belts all ran smooth and true.
There wasn't an oil slinger.
  #177
Old 02-23-2014, 12:09 PM
pedant
I guess your engine is different.
Most timing gear sets I've seen show a slinger behind the seal.
Definitely replace the damper or put a repair sleeve on it before you bolt it down.
Make sure to lube the seal too.
They don't like to be started dry.
  #178
Old 02-23-2014, 01:26 PM
I installed the timing set using the Haynes manual and it read "install the oil slinger (if so equipped) over the nose of the crankshaft".
So I assume some have them and some don't.
  #179
Old 02-23-2014, 02:06 PM
pedant
I'm agreeing with you...
I asked about it while trying to understand why you seem to have an alignment problem.
  #180
Old 02-23-2014, 02:37 PM
Sorry, I didn't mean it like that, I should have put a smiley face
This contradicts my previous statement about taking 1/8" of the balancer. I can't take that much of because the bolt and washer will bottom out on the crank and there might be play in and out.
So I agree now that the timing set can't be the culprit
What else could this be? Am I going to have to shim all the other pulleys and buy a balancer? How much is a repair sleeve?
Let me tell you a story... FoxFord33 Ranger & B-Series 2 01-22-2017 12:58 AM
F150 Resto (Grandpas 85) Chevra 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 10-24-2016 02:41 AM
Contemplating 1972 F6/700 Dump Purchase 94150 Large Truck 10 02-12-2016 01:18 PM
Newbie rockhardplace011 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 11-03-2015 01:24 PM
Alert Incoming New Guy skyde 1957 - 1960 F100 & Larger F-Series Trucks 12 04-22-2015 08:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
