Newbie 85 f250 frame off resto (Image Heavy) - Page 11 - Ford Truck Enthusiasts Forums
  #151
Old 02-21-2014, 05:06 PM
Piston Honda's Avatar
Piston Honda Piston Honda is offline
Piston Honda is starting off with a positive reputation.
No, it is not flush.
  #152
Old 02-21-2014, 05:07 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
That's what I'm wondering from both the first and second pics.
  #153
Old 02-21-2014, 05:50 PM
It won't go in any farther. I measured the depth from the crank seal into the crank and the balancer is bottoming out
  #154
Old 02-21-2014, 06:09 PM
FordFETruck's Avatar
FordFETruck FordFETruck is offline
FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.FordFETruck has a great reputation on FTE.
Quote:
Is this a Ford balancer or an aftermarket one?
  #155
Old 02-21-2014, 06:14 PM
It's a Ford, the original one at that. I haven't changed anything that would make a difference as far as pulleys not lining up.
  #156
Old 02-21-2014, 06:15 PM
Are there any burr's inside of the balancer?
  #157
Old 02-21-2014, 07:02 PM
Quote:
No burr's, smooth as can be. I do see something of concern on the outside of the stub, not keeping it out, but there's a groove in the stub of the balancer. We'll call this line "L1". The old seal must have ground a groove, so I'm sure the new seal will leak. But looking at where the groove is in relation to the thickness of the seal it doesn't look like the HB was in any further then it goes in right now. Unless this groove is there on all stock HB's.
In this pic you can see where the outside of the seal sits on the stub right now. "L2"
.......and where it "should" sit "L3"
Does anyone else see the difference in the shine of the metal between L1 & L2 and then L2 & L3? If that makes sense. It looks to me that L2 to L3 was exposed and wasn't in the timing cover.
  #158
Old 02-21-2014, 07:40 PM
Cole Neese's Avatar
Cole Neese Cole Neese is offline
Cole Neese is starting off with a positive reputation.
Yeah it does kinda look like that. Have you looked closely at the crank to make sure it's smooth? And you've tried putting it on without the key to make sure the key isn't binding it somehow?
  #159
Old 02-21-2014, 08:31 PM
I haven't taken the key out this entire build. Is it a PITA to get it back in?
EDIT: Is it possible a PO changed out the balancer with a different year or something?
  #160
Old 02-21-2014, 08:54 PM
The key isn't hard to get back in, it's harder to get out than in. Just tap it back in with a ball pein hammer.
  #161
Old 02-21-2014, 10:55 PM
Cole Neese's Avatar
Possible I guess, not sure.
I agree, it's pretty easy to get in, a pain to get out though.
  #162
Old 02-21-2014, 11:00 PM
Personally I'd say to hell with that balancer install tool and just use the bolt for it and a breaker bar! I'll bet you it'll go right in and seat fully. I've done mine that way three times and it's worked flawlessly every time. Use a light penetrating oil on the shaft and inside the balancer.
  #163
Old 02-21-2014, 11:17 PM
Cole Neese's Avatar
I agree, and mine just slid on by hand. It fit tight, but I definitely wasn't an interference fit
  #164
Old 02-21-2014, 11:42 PM
Quote:
Mine requires little force with a 16" breaker bar. Especially if you spray it down with a light oil.
  #165
Old 02-22-2014, 12:51 AM
A few things come to mind as the culprits
1. I changed the timing set, the crank gear could be thicker and therefore keeping the HB out that extra thickness.
If you measure from the timing gear to the end of the crank snout, it's 2". If you measure from where the inside edge of the HB( where it " should" sit flush to the crank snout) to the end of the stub it's 2 1/8". So maybe that's why the balancer is out 1/8" from the crank snout and not flush.
2. Water pump has been changed, but the measurement from the back to the front of each pump is within 1/32 of an inch.
3. When I took the water pump off the timing cover originally I don't know if there was a paper gasket( 1/16" maybe) between them. I know for a fact there was no paper gasket in between the timing cover and the block( another 1/16").
So with the two gaskets and the discrepancy of the 1/32" between the old water pump and the new you get maybe a 1/8"+ of stuff holding the water pump out further.
Now...... when I looked under the ring of assembly oil on L2 there is a groove there also. So it seems like the seal is in the exact same place on the HB that it was pre-build.
Are we confused yet?
F150 Resto (Grandpas 85) Chevra 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 27 10-24-2016 02:41 AM
Contemplating 1972 F6/700 Dump Purchase 94150 Large Truck 10 02-12-2016 01:18 PM
Newbie rockhardplace011 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 11-03-2015 01:24 PM
Alert Incoming New Guy skyde 1957 - 1960 F100 & Larger F-Series Trucks 12 04-22-2015 08:47 AM
2002 Econoline work van, 5.4L, no power after long set up RandyJ2007 Modular V8 (4.6L, 5.4L) 6 01-02-2012 09:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
